Question about Maytag Washing Machines
Model Number LAT 9606 BGE noisy on spin cycle
  • 3 more comments
  • rcpiaggio Sep 14, 2009
    I will like to know how to get to the bearing assembly for this particular machine so I can replace it , probably a exploded view for dissasembling
    Thanks,
    Rolando
  • rcpiaggio Sep 17, 2009
    I do hear a roaring noise on the spin cycle, so it is probably the spin bearing as you suggested , I will apprecciate if possible to let me know with diagrams or guidance how can I remove it and repair it , since I have some mechanical experience , my trade is air conditioning and refrigeration mechanic so I do have tools and experience on disassembling equipment , otherwise I wouldn't mind knowing how I can obtain a manual or more information on the subject. Thanking you ,
    Rolando
  • rcpiaggio Sep 19, 2009
    hi,
    I think the noise comes from the bottom of the gearbox , the problem is I do not have a proper drawing of it or how to dismantle or remove from the machine.
    Roland
  • rcpiaggio Sep 21, 2009
    My main problem is that I do not have a manual or instructions to follow of how to dismantle the gearbox The noise is a grinding noise of the type when is a faulty bearing or lack of lubrication . I suppose it is very hard to obtain instructions of how to dissasemble the gearbox and replace the faulty part. The cost of a new gearbox is $ 660 Aus dollars , the sad part is that the rest of the machine is in perfect condition . Thanks,
    Rolando
    I know it sounds silly but where is located the drum b earing ins this machine is like a sleeve but if I remove the drum and move the gearbox by hand I start hearing the sound that is like a grinding noise of a failed bearing but which one ? I have not been able to get a proper drawing and description of parts or how to dissasemble the gearbox that I think is an unusual shape because it looks like a banjo
    Thanks Roland
    President:
  • 1,653 Answers
This is quite a common problem.
Make sure that the filter and waste water pipes are clear of obstructions.
Check that the machine is not overloaded.
Does it make the same noise when there is no load in it and you rotate the drum by hand?
If it makes noise then the most likely problem is the bearing needs replacing. You will need a serviced engineer to call and replace the bearing.
Alternatively, but unlikely is the mounting springs that keep the drum centred have worn or broken due to having heavy loads which will allow the drum to make a load knocking sound when in use.
Posted on Sep 21, 2009
    Sergeant:
    Champion:
  • 208 Answers
Can you describe the noise? Is it like a plane taking off, grinding, clicking, or something else?
Posted on Sep 19, 2009
    Top Expert:
  • Maytag Master
  • 80,530 Answers
How to Stop Washing Machine Noise Model Number LAT 9606 BGE - writer_avatar.gif Contributor By eHow Contributing Writer Article Rating: stars_3_15.gif (16 Ratings) It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Difficulty: Moderately Easy Instructions
  1. Step 1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  2. Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  3. Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  4. Step 4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  5. Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  6. Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Posted on Sep 17, 2009
  • 388 Answers
How noisy is it? Do you hear a thumping sound and the washer seems to want to "wallk"? If so, the laundry load is unbalanced and needs to be redistributed in the basket. Is it noisy like a whining or grinding noise? If so, it could have a bad bearing or the clutch may be going out. Is it a high-pitched squeal? If so, it could be the belt is loose and needs to be replaced.
Please let me know if I am on target or not so I can help you further with this issue. Thanks!
Posted on Sep 14, 2009
  • 2,200 Answers
Hi
If your machine is making a kind of "roaring noise" when it spins it is likely that the spin bearing is failing and worn out on the machine.
This bearing on its own is around $12 but there is a fair amount of labor involved in replacing it. The machine will need to be dissassembled in order to access the bearing.
Have a look at this link to see whats involved. The model number is different but the concept is the same.
http://www.geocities.com/maytagrepairwasher/index.html
This link provides exploded diagrams your particular machine.
http://www.appliance-parts-warehouse.com/maytag-parts/model_view_cats.cfm?model=LAT9606BGE
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 13, 2009
  • Radio Code Pro
    Radio Code Pro Sep 17, 2009
    Have you clicked and opened the two links I provided??
    One has a walk through and the other exploded diagrams!!
It barley spins
could be tranny if noisy. may be worn dawgs (gear cogs) found inside the agitator. Remove cap and they'll lift out Order by model number
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Mar 15, 2016 | GE WHDRR418GWW 35 cu. ft. Washer
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
I have an issue that is rather strange! On the NORMAL cycle only, at the end when it should turn off, a rinse comes on and wets the clothes. The extra rinse is NOT on, the belt and motor are fine. I know...
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details.
BUT, is this an "LAT" series Maytag washer??
If so, this is a normal rinse, the manufacturer calls it a "Spray Rinse" and it is quite normal.it only adds the water during the spin cycle, after the rinse water is ejected and then only for about 1 minute, the water passing through the fabric as it passes by the water inlet flume and empties during the spin.
Jun 12, 2017 | Maytag MVWC6ESWW Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
Maytag Lat 8434 Top Loader will not cycle
sorry but i dont have much experience with this particular model, so i really have no advice for you, please repost
Dec 03, 2008 | Washing Machines
Washing Machines Logo
215 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
