Can't turn on Dell Inspiron 1501
When I try to turn on my Dell Inspiron 1501, the screen remains black, and I get a blinking light that looks like a lock with the letter 'A' in it. It appears that nothing is happing at all. preceding this problem, I let the battery get down to 6%, when it automatically shut down. Any ideas?
  • 2 more comments
  • Sam Billing
    Sam Billing Dec 11, 2007
    I did both steps, first unplugging and then holding down the on/off button for 13 second, but I am still having the same problem as before.
    Any other ideas?
  • Sam Billing
    I completed both steps, but to no avail. Any other ideas?
  • Sam Billing
    Yeah, I did remove the battery, with it removed turning on the power. The light blinks continually at a very high rate of flickering whenever I turn it on. When I press the on/off button again it turns right off. There is no light on when the cord is plugged in, except for if I take it out, then plug it right back in it will come on for a second, then turn off.
  • Sam Billing
    not the power adaptor cord, but the light on the computer itself that indicates that it is hooked up to an outside power source. It has a little lightning bolt on it, and before the problem occurred, would be lit up when the power cord was plugged into the computer. Since the problem has occurred, when I plug it in, it will light up for about half a second, then turn off. Probably not a helpful detail, at least not as important as the other details. The light on the power adaptor is on when it is plugged in. No problems there.
  • 625 Answers
If you have a cd bootup disk start the laptop with that -or- a floppy.
Posted on Dec 11, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Dec 11, 2007
    ok, the power adapter is working as evidenced by the LED indicator. if you have a voltmeter, set it up for measuring DC power. The center terminal on the barrel type connector is always positive and the barrel, negative. look on the power supply and see what the output voltage is supposed to be. (printed or stamped in it) check the barrel receptacle on the laptop. the center is just a pin, the barrel connection is a curvy spring. if you can get at it, bend the spring closer to the center terminal without touching it. Inside the laptop is a real small fuse in the power supply section. it's about a half inch long, glass with two metal caps. it might solder in or it might have a spring clip for it. check out this fuse. blown - get another one - not blown - check the first primary diode in the input to the power supply. its function is to prevent back current to the adapter.
  • Computers & ... Master
  • 1,113 Answers
Did you actually remove the battery, and with it removed turn on power from power pack as suggested, does the light blink a number of times then repeat?
  • Soulvisitor
    Soulvisitor Dec 11, 2007
    Power supply may be the problem is it lit up green when plugged in?
  • Soulvisitor
    Are you refering to the power adapters light here.....There is no light on when the cord is plugged in, except for if I take it out, then plug it right back in it will come on for a second, then turn off.??
  • 490 Answers
Dear sir , acutully your dell laptop is in hibernation mode, and is not coming back
you can try following:
1. remove batter plug directly and try to switch it on without battry.
or
2.press power switch for 13 sec continusly and once it shuts down , switch on it again
this will definatly help you
thanks
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
My laptop inspiron 1501 will not turn on
Try reseating the RAM in the bottom of the computer. Do the lights blink in any pattern?
Jun 12, 2009 | Dell Inspiron 1501 Notebook
Laptop turns on but screen is black and capslock is blinking... inspiron 1501
put the old memory back in and boot into the BIOS. Check the options: "Quick Boot" and "Boot time diagnostics". These should be disabled and enabled, respectively. Put the new memory back in one stick at a time and make sure they work on their own, then try with both sticks.
Oct 30, 2009 | Dell InspironTM 1501 Notebook
Inspiron 1501 startup problem
hi,
-this is a possible problem in the memory of the computer
-if you are familiar in opening the computer and removing and returning back the memory please reseat the memory; if not contact your manufacturer for possible memory replacement
cheers!
Oct 18, 2009 | Dell Inspiron 1501 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
MY DELL INSPIRON 1501 IS NOT WORKING, THE BLACK
  1. Chck the ram i thinkg ram is not working
  2. insttal the oprating system in your system and remove the old after working fine
Jul 14, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
280 people viewed this question
Alun Cox
David Payne
David Payne
