Question about Brother CS-6000
Brother ES2020 Help Identifying broken Part
I had an E6 message on my Brother ES2020- working fine for 2 years but sewing some stretchy fabric the thread got tangled.
I tried to manually turn the wheel as the needle was down, but the needles broke off - not a problem - replaced.
But the thread was caught underneath and I couldn't get it out, despite snipping the loose bits as I bulled the bobbin case out a piece has broken. It's really tiny, cant quite see how it happened
My manual says that's the "spring" it keeps the bobbin from spinning too far around, it is an L shape like a right angle and you'd see it if you lined up the bobbin when replacing.
It's snapped off, but I can't seem to find a part number to order a replacement. Am absolutely positive I can't use it in it's current state.
Anyone have any ideas or should I just take it to a service repair? I'm in Nottingham UK.
thanks folks, midway through making a new project and now left with fabric and thread all over the table with an un-useable machine... :(
fury2525
SOURCE: Loud and punching through fabric
I have had the same thing happen to me even when I was on the phone with a brother tech, I went step by step with her, she told me to turn the machine off and then on, so it would clear it.
This was happening some when i was having problems just trying to wind a new bobbin.
ps. If other brother owners are not aware bother has a dvd for several machines that is put together very well in how to use your machines.
and its free for the asking and they pay s & h.
Lish
Posted on Jun 09, 2008
dizzythevamp
  • 9 Answers
SOURCE: Needle thread getting caught in bobbin are on Brother Cs-100
I don't know if this is any help, but I would suggest taking it in to a repair store. So here is a way to find places that repair brothers machines. The place near me has done a great job both times I've gone in. Also they usually don't charge for labor, just parts. If they charge for labor it probably won't be much.
http://www.brother-usa.com/service/
Posted on Jan 06, 2009
SOURCE: machine is telling me E6 error but there is no thread tangled
I am in the middle of fixing this same error. I phoned Brother service in Manchester and they are spot on. Give them a try, they talk you through the problem and suggest things to do to narrow down the cause. Make sure you have the model and serial number as this saves time. In extreem cases you can send your machine to them by parcel post and they will look at it free of charge and then give you an estimate for any repairs needed. If you decide not to go ahead, you can elect to have the machine returned to you for the cost of the postage.
In my case I bought the machine second hand off of E-bay and was getting the dreaded tangle/needle message. I phoned the service department and I was told to thread the machine up and switch on. Then they give you several things to try. Essentially you need to get someone to press the start button while you immediately turn the handwheel forward gently and smoothly.
If this stops the message coming up then you must suspect the motor or its fuse. In my case, it would seem the machine had been dropped as there was a hairline crack in the circuit board which stopped the power getting to the motor.
Posted on Jul 30, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
SOURCE: My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Posted on Jul 29, 2010
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
First the top tension started being loose, so I changed the tension different ways and tried to fix it...now the thread is getting all tangled up under the fabric and is locking up. Also giving me the E6...
Do you mean the stitching on the top of the work was loose? If so, you should check the bobbin tension. Make sure you have the thread pulled under the tension plate or spring on the bobbin case. Tension should be just enough that you can suspend the bobbin in the case by the thread (think yo-yo). Upper tension should be tighter than lower. Make sure you put the presser foot down.
Sep 01, 2011 | Brother CS6000i Computerized Sewing...
I keep getting the E6 (tangled thread) message on my Brother CS600 when I try to sew. I have check for tangled thread and cannot find any. Could it be that the bobbin case needs to be replaced? It seems...
is the bobbin case damaged in any way?
try turning off the machine & unplugging it & then replug it back up & turn it on & see if that clears the computer parts of the machine
if it still shows a E6, then you can replace the bobbin case or you might even consider having it serviced
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
I had sewing machines E6 computer bother a few yeas . Now I sewing , it turn E6 . what does E6 mean? Can you help me . How to fix it? Thank you.
Download a free manual from www.brother-usa.com and under support and put in your model number. E6, means that the thread is tangled, totally unthread it, now with the presser foot up, rethread, pull the top thread, now lower the presser foot and pull the thread, it should barely move. This will seat the thread in the tension discs. Read your manual before using, it will save you lots of grief. People love to skip this step, and wonder why the machine is not working right. This is one time you should take the time, it is worth it.
Apr 11, 2011 | Brother CS-6000
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My sewing machine will sew for about 2" and then
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
Above is a link to the PDF file for you sewing machine.
The error message E6 is The motor locked up because the thread tangled.
Solution - Remove the tangled thread before continuing operation.
Jan 17, 2011 | Brother CS6000i Computerized Sewing...
I am using my Brother CS-6000i sewing machine for the first time and keep getting the E6 error code. It worked fine for the first 2 rows of stitches I did then I got the error and the thread was tangled. I...
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
Jan 09, 2011 | Brother CS-6000
Lish
Apr 18, 2008 | Brother CS6000i Computerized Sewing...
Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
May 19, 2007 | Brother CS-100-T Computerized Sewing...
Brother CS-6000 Logo
149 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
