Question about Sony Ericsson Z310i Cellular Phone
My sonyericsson z310i's display gone dim.
Meant tht no display of images or text, there's only light from screen. i manage to use extra small screen for identifying callers. but it s not adjustable. I wish a solution. if the solution is to change the mobile software, is it possible to change the software via a PC by myself. if so plz send step wise procedure. pls help me
Hi! My screen has gone blank on my wharfedale docking station and it isnt responding to anything! I'm not sure what's wrong with it?!
The first place I would look is to the screen lighting mechanism. To prove the display is actually working, you should be able to catch a reflection of very dim images on the screen in bright light.
Hope this is of some use to you.
~/Lee
May 24, 2015 | Computers & Internet
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
No image - only the back light is on. No desktop display
if it's new then get it replaced...
else u need to get it fixed from a tech shop....one of the below is @ fault....
1 the LCD screen is gone,
2 the backlite (a small tubelite) is gone
3 the invertor board(a small PCB) behind is gone
May 10, 2010 | Apple PowerBook G4 Mac Notebook
My screen has gone dim on my ibm thinkpad r50e, when trying to boot just kept goin in circles wouldnt load windows, so have restored factory defaults! but screen still dim? can you help please
if the screen is dim and the images still display it means that the it's probably the CCFL tube or the inverter (located in lcd panel) it will need to be replaced.
Mar 06, 2010 | IBM ThinkPad R50e Notebook
Sony ericcson z310i blank screen
display ic is out so change the the display contact sony ericsion customercare
Sep 11, 2009 | Sony Ericsson Z310i Cellular Phone
Need a manual for z310i
http://www.nodevice.com/user_manual/sony_ericsson/phones/z310i.html
there you go mate
chris
Dec 15, 2008 | Sony Ericsson Z310i Cellular Phone
Phonecell - PC Connecting
You can download software etc. at the SonyEricsson site:
http://cmsprod.extranet.sonyericsson.com/cws/support/products/z310i
Goto: software downloads, and select the version you need.
Note: you will need either a cable OR a blue-tooth adapter.
Cable is more secure, blue-tooth can be used for more than just you (current) phone. Price is about the same......
Oct 28, 2007 | Sony Ericsson Z310i Cellular Phone
Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
Sony Ericsson Z310i Cellular Phone Logo
299 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
