Question about BenQ FP71E 17" LCD Monitor
BenQ FP71E turns off after 2 secs- Logo flashes then turns off
This has suddenly started today. I notice that the screen had turned off. At first I thought a power cable was loose but this was not the case. Pushing the power on button on the front of the unit -- the light turns blue for about two seconds -- the start-up BenQ logo on the screen flashes up then the unit turns off.
It has never had problems before.
LCD monitors behaving in this fashion more than likely have a faulty inverter. Refer www.lcdparts.net for solutions.
Posted on Sep 27, 2009
I have two of these monitors and they both failed with 4 weeks of each other. Read on another site the guy went around the circuit board tapping all components with the handle of his screwdriver, it worked. This indicates to me a dry solder joint. So will try with mine, bit by bit and see if I can localise the offending parts.
Posted on Nov 23, 2009
  • Chambo53 Oct 15, 2014
    These monitors have a power supply sub board that takes the mains power. Power supplies are always the hardest working component of any system. I replaced the sub boards, all fixed. Sub boards are available from BenQ.
Have the exact same problem as well. Pulled it apart and the capacitors seem superficially okay. Not sure what to look at next.
Posted on Nov 22, 2009
Mine just happened aswell today, same monitor and everything, having a read around sounds like it is the capacitors on the circuit board but having little to no experience looks like ill be getting a new monitor
Posted on Sep 14, 2009
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | BenQ FP71E 17" LCD Monitor
Wont power onPressing power switch, blue light comes on, the BenQ logo briefly flashes then screen stays black
Power leak causing overload on the O/L sensor.
Probably a faulty capacitor on the power board
Sep 07, 2009 | BenQ FP71E 17" LCD Monitor
Check to see if the video cable is connected at both ends securely.
Also, if possible, try another cable.
Jun 09, 2009 | BenQ FP71E 17" LCD Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
1,304 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
