Question about Cameras
Hello samsung l310w camera still does not work. this time the lens does not come out, when i turn on the camera. when i turn on the camera all it does is beeps twice and then turns itself off. please help, because my other camera is rubbish, and that one does not zoom in fully.
  • rondunn60 May 11, 2010
    hello I have a samsung l310w camera the lens does not come out, when i turn on the camera. when i turn on the camera all it does is beeps twice and then turns itself off. this was after my 2 year granddauther got her hands on it. any advice
    President:
  • 2,761 Answers
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
MY SAMSUNG PL120
Hello.
Used - full work.
ebay.com
Item number:170740619194Item location:morrow, GA, United StatesShips to:Worldwide
Nov 11, 2011 | Samsung PL120 Digital Camera
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
My samsung st700 is brand new have it only a week and it has stopped working. when i turn it on the lens extents and then it stop, i have no screen and it will not respond and then the lens wont retract....
If you have been using this camera outdoors, then the one causing your problem is a grit of sand jamming the lens. Hold your camera with your right hand with the lens facing the ground. Next, tap the camera's base to your left palm while powering on the camera. You might want to do this several times. If it still wont work, and you can avail of the warranty to save repair cost.
Hope this helps.
May 12, 2011 | Samsung DualView ST700 Digital Camera
I have the Samsung L310W digital camera. I have 3
connect the camers to computer by datacable and try to format the memory card through computer ...
Thank You ...For using FIXYA...
Dec 03, 2009 | Samsung S860 Digital Camera
Samsung camera still not working
I personally have had great luck with the Kodak Z650. It's an inexpensive full featured camera that provides a good zoom ratio (10x optical + 5x electronic = 50x zoom), the convenience of a charging dock that lets you connect to your computer AND charge the camera by simply dropping the camera into it, and plenty of available accessories. I have two of these cameras and I recently gave one to my daughter and her husband. Kodak.com is a good source for these (new & refurbished), and eBay is probably an even better source. AVOID the Kodak printer dock though. Quality is poor, and they are prone to multiple problems.
Don't give up on the Samsung yet, though. The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Cameras
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Aug 04, 2008 | Samsung NV10 Digital Camera
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax A7 Digital Camera Problem
My camera will not turn on , it froze last month whilst the lens was out so i pushed it back in and it started to work fine this time it has forze or broke with the lens inside and it will not turn on the batteries are fine but i cant turn the camera on?
Nov 05, 2007 | Samsung Digimax A7 Digital Camera
Cameras Logo
517 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
