Sharp tv 13vtr100. when I turn on power as soon as screen starts to light up power shuts off. The power, wake timer light flashes constantly and power will not turn on untill I unplug and plug in.Then the same thing happens
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Any experience with a main board swap on a lc52le640u Sharp Television?
I would start by checking power supply voltages which should be printed near the output connectors.
Feb 03, 2015 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
regards
shaun
Jan 25, 2014 | Televison & Video
I have rear projection tv sharp 55u-wp7h. Unable to turn on tv due to view timer automatic turn on. what cause that and how to fix the problem?
I'm having same issue with same TV. It powers off after about an hour and red power light starts flashing. Only way to power back on is by unplugging TV and waiting a while, then plugging it back in, but then the TV will turn off again after a few more minutes, red light flashing again. I've checked the sleep timer and it is turned off, so any other solutions to this problem? All capacitors on power board look fine (not blown). I've read it could be solder joints in power board need to be resoldered.
Dec 17, 2010 | Sharp 55R-WP4H 55" Rear Projection...
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
Dec 06, 2010 | JVC AV-27D302 27" TV
TV won't turn on
Have you tried switching inputs? On some sets if it is set to s video all you get is a dark screen. Check your connections if you have other inputs. If you can't switch you should at least get the menu on the screen proving the tv is working and it is a setting.
Sep 18, 2009 | Televison & Video
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
37mf231d power light flashes on and off will turn on after you keep trying
set the time on your tv and turn off the timer, sleep and wake funtions.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
RCA VR601AHF
I just had this same problem. I thought that the timer was stuck and was the reason why the VCR wouldn't play. I just moved and thought the unit got broken in the move. However, I think it was just not hooked up properly to the TV. I unplugged it, plugged it back in, and got it hooked up properly and it started working again (I tested the connection with a DVD player first). The flashing timer light went off as soon as I reset the clock. It seems odd that having it not hooked up properly should stop the VCR from playing, but that is what seemed to happen in my case. Hope this helps.
Aug 16, 2007 | RCA VR622HF VHS VCR
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
