Question about Canon PIXMA MP970 InkJet Printer
Memory card stuck in the SD slot
I have a smaller memory card stuck in the SD memory card slot and cant get it out? any suggestions?!
    Problem Solver:
  • 17 Answers
Ohh
its a viurs.if is it nt detect virus gard
try to make externel memory card reder and dnt open.1st activate ur hiden fils and folders and go to memericad rigcht clik explor and del all hiden files specialy aoutorun.inf file del. and copy ur doc to pc then good for format ur memory card. tnx
Posted on Sep 13, 2009
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Just bought this Kodak Easyshare DX7590 used. Radio Shack sold us a 4 GB SD card for it. When we insert it into the camera, it says "Memory card needs formatting". When we try to format it, it...
The 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller with the DX7590.
Nov 20, 2010 | Kodak EasyShare DX7590 Digital Camera
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
The m2 adapter i have does not fit my acer aspire laptop yet my laptop card reader says it reads m2 memory cards. is there a certain way of putting the card in to the memory card reader.
I think that with smaller memory cards like m2 and t-flash(micro SD) you would have to use their adapter(a card with a slot that normally converts it to SD) before you can slot it in.
Nov 06, 2008 | Computers & Internet
SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Jan 18, 2008 | Toshiba Satellite M35X-S161 Notebook
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Canon PIXMA MP970 InkJet Printer Logo
449 people viewed this question
old marine
old marine
