Question about AT&T Blackberry Curve 8300 Smartphone
M y screen lens front is damaged how can it be replaced. I have the replacement
Http://www.youtube.com/watch?v=20Vb3BHrk-c My suggestion is to contact this link/video.
Rod Evans
Posted on Sep 14, 2009
Just wanting to know how to remove the front screen to clean the dust of the projectors
You can do that but an easier way is to remove rear cover (set unplugged)and clean the lens with a lens cloth or paper towel with glass cleaner sprayed on it.
It is fairly easy to damage screen when removing it/replacing it.
Let me know what you find.
SD TECH
Aug 12, 2011 | Hitachi 57F510 57" Rear Projection...
I have a sigma 18-35. It has not been used in a while and mold has formed on the inside of the lens. How can I open it up to clean?
Hi
to remove the front lens you will see a ring that you can peel off and you will see
4 screws take them off and the front lens will come off
Oct 12, 2010 | Sigma 18-35mm f/3.5-4.5 Lens
Can I replace the LCD screen on my Nikon P80 coolpix camera? One of the kids dropped the camera, the LCD Screen shattered and I want to replace the screen. They have them on Ebay for about $45...
ya you can replace the screen, it should not be that hard. i know people who have replaced there camera screens. there camera screen works like new
Nov 27, 2009 | Nikon COOLPIX P80 Digital Camera
BLACK SPOT ON TV DUE TO DIRECT SPRAY ON SCREEN
The lenticular lens will have to be replaced. It is not an easy task to do as there is quite a bit of tear down needed to do so. The part number for the screen is 2-590-450-01 there is also a screen right behind the lenticular called the fresnel lens which will possibly get damaged taking the unit apart. The part number for it is 2-590-449-02. I would suggest having a technician do the replacement, that way if they damage the replacement screens its on them and not you. Please take a moment to rate my answer. Thanks...
Nov 25, 2009 | Sony KDF-E42A10 42 in. LCD Television
My cinego projector was dropped and now shows a line down the screen
if it was dropped on the front, the lens might have cracked. if it's pixelated, you damaged the dmd chip and you might as well replace the projector.
Jul 12, 2009 | Radio Shack Cinego D-1000 Multimedia...
RU -44, small "pink" spot on screen.
Green is missing from the area where you see the pink (actually magenta) spot. This might be due to a large amount of dirt on the green lens. It may be due to damage to the face of the green picture tube. You need to remove the front screen so you can look into the lens and determine that.
Depending on the make and model of TV, the screen may be held on by snap fasteners and come loose when you pull on the plastic bezel surrounding it. Or the bezel may pull off to reveal brackets screwed into the cabinet that secure the screen. Or there may be a trim strip under the screen that pulls off to reveal screws. Remove those and the screen will swing up and off.
Once you can see the lenses, clean them with a soft rag and glass cleaner. With the set on, look down into the lens and you can see the face of the picture tube. If you see a dark spot on the face, the tube is damaged and would need to be replaced
Apr 22, 2009 | LG RU-44SZ61 44" Rear Projection...
Blackberry 8700g screen lens replacement directions needed
Hi.....don't know if you have already resolved this problem, but if not, you can view this video on you tube which shows you exactly how to do it. This doesn't say 8330 but still applies same as the others.  BlackBerry 8300 8310 8320 lens replacement proceedure
Apr 19, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Fixing scratches on front of screen
I doubt it will make much difference, but try lens cleaner, check this link.
http://www.brightsolutionsinc.com/
Any commercial grade plastic cleaner/ buffing soloution might be worth a try.
The product may damage the outer screen though. I recently replaced all 3 for about $500 after my kid shot them out with a BB gun.
Sep 01, 2008 | Toshiba 51H84 51" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
BROKEN SHIELD
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Sep 21, 2006 | RCA P61960 61" Rear Projection Television
AT&T Blackberry Curve 8300 Smartphone Logo
46 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
