Question about Onkyo TX-SR703 Receiver
Video distortion I have all my a/v components routed thru the receiver via component in and out to tv. I noticed a scrolling lines on the scrren wheather there is a imput signal coming thru or not ( for example dvd, cable) didn't see any going straight to tv
I have seen this a couple of times in my 12 years
Try a farite coil on the tv power cord
also try un plugging the cable line from the cable box or tv to see if a grounding issue occurs
to fix the grounding issue try putting a small wire on the case screws running the wire between the cable box and the stereo rcvr
Posted on Jun 01, 2009
Only thing I can suggest would be:
A. Look for any magnetic or other interference on any of the cables if there are bare wires somewhere.
B. Get a separate video switcher or run all your video to TV. If you are using component, the signal is a low quality anyways, but the same can happen to any type of connection
Posted on Apr 05, 2009
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
How to hookup all the units ,cable, vcr, dvd , tv.,and receiver
It all depends on what you have for inputs on TV really. Any video components should be hooked directly to TV via, best, HDMI, next, component. Component has great video but doesn't carry audio, for audio, you would have to use separate cable(s), digital optical being best. The best scenario would be to run cable/sat, dvr, etc, to TV then hook TV audio out, via digital optical, to reciever. You would use TV's menu to choose what you watch and, would have one audio out to reciever. Some, if not most recievers have video pass through but, it's not the best route and, you have more connections and more margin for error.
Jun 14, 2011 | Audio Players & Recorders
I have the receiver hooked up to a Sony TV via component video. When watching cable TV the colors are really off on the TV. However, while watching a video (DVD), the TV's picture is great. Is this a...
I don't know what kind of tv you have but, receivers can pass video along to the tv but, are not the best way to go. If you have the capability of running your video components dirctly to tv then sound out to receiver, you would get better results. Component video is great, as good as or, better than HDMI, the only advantage to HDMI is the audio but, digital optical for audio is great also. Component video cables can be tricky because you have to make sure the connectors are in all the way. If they are not inserted properly, you probably notice too much blue or green. While watching your cable, try twisting and pushing connectors and see if you notice any change in the color quality
May 22, 2011 | Onkyo TX-SR602 Receiver
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Jun 30, 2008 | Yamaha HTR-5930 Receiver
Onkyo TX-SR703 Receiver Logo
109 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
