Question about Garden
Not recieving full power at high revs flooding wont idle on low revs
  • 31 Answers
First change the plug and the filter in the gas tank. If problem persist try setting the air fuel mixture. I would recomend letting a pro do this setting you could get the mix to lean and burn a hole in the piston.
Posted on Sep 13, 2009
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
I can't start my home lite 26b blower
Mike if the Blower wont start, it's not the High/Low Jets.
They only adjust High RPM running and the Low helps the carb transition from Idle to High rev.
Ethanol gas is a carburetor destroyer... Also, it eats the gas lines .
Jun 27, 2015 | Garden
How do i adjust my idle crew
The idle screw isn't as important as the low/high setting on the carb. Start with one turn out on both low and high side settings.
Aug 30, 2014 | Homelite Garden
How to set the high and low
Turn mixture screws completely in gently, then wind out 11/2 turns each. The saw will be able to start and run at this point. On idle wind Low clockwise till motor starts to die then anti-clockwise 3/4 turn.
High speed is a little more difficult, On full revs wind clockwise till saw starts to rev out (lean Mixture) then back till the sound starts to bubble.
Jul 26, 2014 | Husqvarna Garden
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
Engine dies upon acceleration after starting and idling
turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
Jul 02, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My jet ski starts fine, goes slow, when i give it gas the rpms rev high but it wont go any faster than the low idle speed
You are dealing with moisture in your electronics box or moisture corrosion in you carburetor. Take you carburetor apart and clean it . Make sure the needle is not sticking and do not alter the spring in any way.
Jun 16, 2010 | kawasaki Full Suspension Mountain Bike Men
I have a hb180 homelite leaf blower and want to know how to adjust the 'two' little screws on the side and what they do
if its the carb screws your talking about
one it for fule mixture the other is for air,,,
air for tickover fule mixture for rev's
if its running well leave them be?
Oct 30, 2009 | Garden
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
