Question about Nokia E63 Cell Phone
E63 hangs!! i open apps and nothing happens
I've installed a couple of apps on my E63 and now its seems to hang a LOT. not because of more apps, but when i open certain aopps, it does not open and the phone hangs. Theseapps used to start easily before. Even the nokia Energy profiler won't open now. Also, i've scanned with kaspersky antivirus on my phone but no virus found not even in RAM scan.
Pls. help!
  • Anonymous Mar 13, 2014
    I AM UNABLE TO OPEN FOLDER IN APPS THAT IS MY APPS
  • Anonymous Mar 28, 2014
    My iphone4 hang a lot when open any app or other
    Problem Solver:
  • 6 Answers
1. you need to reboot your phone by pressing no. 3 + * + Power button simultaneously and the phone will be back to its original factory setting (fresh) - hard reset
MAKE SURE YOU BACK UP ALL CONTACTS, MESSAGES and OTHER DATA
2. It seems that you have installed a couple of "untrusted" third party application such as Iphone themes, games,etc
I happen to have the same phone with the same problem and now its okey.. hope it helps :)
Posted on Sep 14, 2009
Why is it hanging regularly?
If its a low budget phone its probably not enough ram. For a good phone you need at least a gig. It may also be crupted data. At worst it just a reformat job. It may be a app to. Like Facebook, wifi searching apps. They take a lot of processing. You could try forcing close app that you aren't using. Games, social media, maps. To do this go to settings. Then fine your app manager. Go through the list and click on the app that your want to close. Then click on force stop. A lot of app when installed. Are set to startup when the phone starts and run constantly. Suckling alot of memorie and battery.
Jul 04, 2015 | Cell Phones
Hanging e63 whatsapp
As E63 and the like have a very limited RAM and many apps running in the background, like email etc, the RAM falls short and the device hangs. If you can ensure no apps running in the background then WhatsApp will run.
Oct 23, 2013 | Nokia 1661 Cell Phone
Touch Screen Stuck On Incoming Call Screen?
Just Unplug the Power Supply and replug it in after 5 minutes, That should be able to fix the issue.
May 04, 2013 | Lexmark Platinum Pro905 multifunction...
Solution nokia e63 hanging problem
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 15, 2012 | Nokia E63 Cell Phone
I have problem opening my app for hanging friends...
If it hangs at the start screen of Hanging with Friends, then it just means that your software is outdated. It requires a higher OS, so make sure that you've upgraded to the latest iOS software that is on your iPhone, (the most recent is 4.3.3) and this shouldn't be an issue anymore!
If this problem still persists, then please make sure you have enough memory (delete applications you don't need, if possible!)
Jun 29, 2011 | Zynga iPhone Apps
I have installed untrusted nokia e63 theme after installation its hanging anyhow i switched to other mode pls suggest me how to remove the hanging one theme withour factory setting
THE ONLY SOLUTION FOR THAT IS TO RESTORE YOUR PHONE INTO FACTORY SETTING. you can also save your files and contacts to your PC via nokia pc suite (the latest one) and start resetting your phone. thats the only possible way to restore your phone deleting the hanging theme.
Nov 02, 2010 | Nokia E63 Cell Phone
Hangs a lot!
The hanging of your phone may be due to low phone memory.Try deleting some data from phone memory.Frequent rebooting of your phone may be due to software problems.Please update your firmware or re-install your phone's software.
Jun 27, 2009 | Nokia 2680 Slide Cell Phone
Handheld is hanged
Sounds like you need to do a hard reset, Take the battery out fo the phone while the device is on.
This will rebuild your apps, and should fix the corruption.
Other wise you might have to reload your apps or your os on the device.
Mar 04, 2008 | RIM BlackBerry 8700g Smartphone
Nokia E63 Cell Phone Logo
703 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
