Question about Sony PlayStation Portable (PSP) Console
PSP Anti-static solder point removal
Hi, i really need help!!
My psp's laser isnt working, so i bought a new Laser lens on ebay, and apparently you have to remove the anti static solder!! I have no clue where the solder point is, and i dont know how to remove it!!! PLEASE HELP ME!!! THANK YOU!!!!!
  • 3 Answers
It is helpful if you get some desoldering braid from your local diy shop. you just heat the braid on the solder joint and .... zip... the solder runs up the braid.
hope this helps
danolsta
Posted on Jan 13, 2008
The Anti Static Point is a small bit of metal on the electric strip coming off the UMD. You can see it in the left hand side of this picture.
http://www.psxboy.com/syssite/home/shop/1/pictures/newsimg/1190737097.jpg
Anyway if you look at your broken one you will see it ins't there. So you need a soldering Iron to take it off. I am no expert but as I understand once this is gone the UMD should be fine for installation.
Posted on Dec 11, 2007
My psp says that the disc is unreadable on multiple occassions for no apparent reason when the game works fine in my cousins psp
Sounds like there is a problem with the disk drive in your PSP. Open up the disk tray and look for the laser. Take a (very) damp q-tip and lightly clean the laser and gently push the laser center. If this does not work you will need to replace your PSP laser or send it in.
Jan 07, 2011 | Sony PSP (Piano Black)
My psp wont read any games do you know why this is?
Try cleaning the lens of your ROM. I believe they make lens cleaning discs for the mini ROMs like those in your PSP. If cleaning the lens doesn't fix the problem, then your Mini-disc ROM is likely malfunctioning \ broken. If this is the case, and your PSP isn't under warranty anymore, then you're probably better off buying a new PSP, because it will cost more than it's worth to have the ROM fixed or replaced by a professional - if your can even find someone capable of fixing it for you.
Aug 14, 2010 | Sony PlayStation Portable (PSP) Console
Broken PSP
when you say scanner do you mean laser that reads the umd?
you could replace the laser from one off ebay
but the thing with replacing lasers is that adjusting the laser so it reads the disk it tricky
here is a shop that repairs lasers in psps
http://www.ipaqrepair.co.uk/ipaqpart1418.html
or if you want to do it your self
http://cgi.ebay.co.uk/Sony-PSP-2000-Slim-Original-UMD-Laser-Lens-Repair-Parts_W0QQitemZ290386195846QQcategoryZ127746QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BIEW%252BFICS%252BUFI%26otn%3D11%26ps%3D63
also you say it is 1 year old from brand new? bought from the shops
call sony as it may just be under warenty
Dec 30, 2009 | Sony PlayStation Portable (PSP) Slim...
Ps 2 slin not spinning just replace old laser by new one
Sounds like either you got a bad laser, or if the anti-static solder point on the left side of the new laser was not removed with a soldering iron, then the laser will not work. Simply heat it with an iron and maybe some solder wick and you should be good to go.
Nov 27, 2009 | Sony PlayStation 2 Slimline Console
Ok so my laser went out in my xbox 360 and i bought a new one and i put it in and now it just wont turn on.... what happened?
there is an anti-static point that needs to be desoldered for the new laser to work. Check the link below and then select what drive laser you are trying to replace...
https://xbox-experts.com/e/tutorial.php?n=laserreplace
Mar 06, 2009 | Microsoft Xbox 360 Console
PSP 2003 laser problem
Yes. The lasers are all the same the only difference is the size of the actual UMD enclosure which is only different with the phat (slightly thicker) just make sure its the right UMD tray.
Jan 20, 2009 | Sony PlayStation Portable (PSP) Console
Help
Hi Bvogel987,
You probably need a new UMD drive. I have seen this many times. Try the following to restore the drive.
  1. Turn the PSP-1000 on,
  2. Open the UMD door
  3. Press down on the black peg poking up at 8 O-Clock in reference to the disc spindle.
  4. You should see the disc spin, and Laser light up. If either does not, then you need a new drive.
  5. If they do spin and light up, Take a toothpick, and wrap paper towel aorund the tip of the tooth pick,
  6. Dampen the toothpick swab with a Windex type cleaner.
  7. Swab the laser lens, and move the lens with you finger or toothpick to the right a couple of clicks. Place a new paper on the toothpick and dry the lens.
  8. Test. If this did not work, you still need a new Drive.
I run www.PlayStationClinic.com and we replace PSP-1000 UMD drive for $47.00 including return shipping and handling.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
Cannot read disc
Your laser probably broke.
You should replace the laser module. You can order one at online shops like http://www.consoleparts4u.co.uk/ or buy a cheap laser part on eBay, but watch out with buying components that are made in China/Hong Kong. There is a bigger chance of bad quality.
There is no soldering involved into replacing a PSP laser part. But you should watch out with static electricity and i recommend you following up a disassembly tutorial, for example the one here: http://www.consolezombie.com/PSP/PSP_Laser_Replacement.html
Sep 06, 2008 | Sony PlayStation Portable (PSP) Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation Portable (PSP) Console Logo
1,148 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
