Question about HP Color LaserJet 2600n Printer
Continuously red marks on the middle of the paper
  • 65 Answers
Replace the magenta toner cartridge.
Posted on Sep 13, 2009
When printing a picture, in the middle of the picture I get white marks like the ink is not adering to the paper any suggestings what I can do???
Your printer's hesd is defective. Change it.
All Star Expert Achievement Badge Fixya
Fixya com Customer Support Products Repair Manuals Troubleshooting on Any...
When printing picture in the middle of the picture get white marks like...
Superstar Expert Achievement Badge Fixya
Jul 11, 2015 | Dell Multifunction Colour Laser (1235cn)...
Cannot remove the paper jam
To clear the message Paper Jam from the display, follow the steps listed below:
NOTE: images shown below are from a representative product and may differ from your Brother machine.
STEP A. Check for and remove any jammed paper or foreign objects in the machine
  1. Unplug the Brother machine from the power outlet.
    Caution Before you unplug the machine from the power source, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  2. Lift the scanner cover using the plastic tabs or finger holds, located on the left and right side of the machine until it locks securely into the open position.
    Caution DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band (outlined in red as shown in the picture below). If the encoder gets markings or debris on its surface, it may cause other problems.
  3. Verify the location of the print head. The print head is a black square object, located behind the encoder strip. The print head moves from left to right.
  4. Move the print head to the middle using your fingers.
    Caution DO NOT touch the encoder strip (marked in red shown below).
  5. Check for and remove any ripped paper or a foreign object in the left corners or underneath the print head.
    Hint The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
  6. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper.
  7. Close the Jam Clear Cover. Make sure the cover is closed properly.
  8. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
  9. Remove the paper tray (1) from the machine.
  10. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
  11. Using your hand, lift the front of the machine approximately 6 inches off the surface.
  12. Look inside the tray areas roof of the machine and a row of black rollers will be aligned across. See picture below.
  13. Look in-between each of the black exit rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
  14. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
  15. Place the machine gently down onto the surface.
    • If no paper scraps were found inside the machine, please check the paper in the tray. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper in the tray must be replaced and continue to STEP 16.
    • If paper scraps were found and removed from the machine, continue to STEP 16.
  16. Put the paper tray back into the machine.
  17. Plug the power cord back into the power outlet.
    • If the LCD displays the date and time, go to STEP D.
    • If LCD displays the message "Paper Jam" go to STEP B.
- If the print head is on the right side:
  1. Plug the power cord back into the power outlet and wait for the machine to stop making noises.
  2. Press the Stop/Exit key for approximately 5 seconds until the print head moves to the middle.
  3. Unplug the machine from the power outlet.
    Caution Make sure to unplug the machine. The print head may move and injure your hand. Before you unplug the machine, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  4. Examine the right side of the machine where the print head had been positioned and underneath the print head and remove any pieces of ripped paper or foreign objects.
    Tweezers may be used with caution to remove paper scraps or the foreign objects.
  5. After confirm the paper scraps or the foreign objects in the right corners or underneath the print head, go to STEP 6.
Mar 10, 2011 | Brother MFC255CW All-in-One InkJet Printer
I accidentally pulled wires out and forgot to label them while replacing the convergence chips and now i have no idea where they go. Is there a diagram or anything visual to show me where they go?
If you will misplace them - it's not going to damage anything in several minutes after turning on your TV. Mark them like 1, 2 3. Remember position of sockets on the board. You better use piece of paper and start write down combinations. put them in any position (actually you can see how wires can be put in most "natural" position). Start TV, push "menu" button and check image out. If colors way too apart - try another combination. There is not too many of them anyway. Before you start - check id sockets are marked with some colors like green red or blue. Appropriate socket always marked on the board with name "green" etc. After some manipulations you will be able to find combination that brings colors more closely together than others. Another tip - green socket normally between red and blue. Find wires that connected to the middle CRT (green projection tube) and plug it into the middle socket. figuring out red and blue will be just worst case scenario in two attempts.
Regards.
Russ.
Aug 11, 2010 | Philips 55PP9352 55" Projection Television
6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
Canon pc981
either dubree on the rollers or on the corona wires, wires clean with acalohol and q-tip, very carefully or you will brake the fire, look where the line is at and open the machine and locate where the issue is and remove and clean this area very carefully.
rod
ps
type in address bar
canon pc981 l170 a mark down the middle of paper
enter
rod
Feb 06, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
HP Color LaserJet 2600n Printer Logo
106 people viewed this question
Seeker5211
Seeker5211
