My epson printer delays while printing job is sent to it.
  • 20 Answers
Apart form changing the Advance Settings from the Printer Properties (i.e. Print directly to the Printer) we can change the Priority of the Print Spooler to make the Printer working fast from the Computer.
The “Priority” of a task is the degree of urgency that the task presents to the Processor- Request from a task with higher Priority are served earlier.
Now the default setting for Print Spooler is to run at Normal Priority. Now if the Customer mostly use his Printer for printing form Computer, we can make the Print Job faster by change the Priority.
Here is the Solution Below:
1. Open up the Registry Editor
2. Navigate to :
HKEY_LOCAL_MACHINE/ System/ CurrentControlSet/ Control/ Print
3. Right Click on the Print folder and create a new DWORD value called “SpoolerPriority” and set it according to what value you want or if it exists, just
set the value.
The value are as follows:
OxFFFFFFFF for IDLE Priority
0 for Normal Priority
1 for High Priority
Posted on Sep 14, 2009
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
In our home office we have two HP laptops, both running Windows XP and Office 2007. We connect to our work group through a wireless network. Our Epson TX610FW printer is connected to the wireless router....
Two and a half minutes for each print job is certainly a long time to wait considering that you're only printing a Word document or an email. Some printers go into a standby mode when not in use in order to conserve power and once a print job is sent to it it then performs self checks and warms up before printing which can take some time. Does it still take two and half minutes to print a job directly after printing the first one?
May I suggest that you delete any old printers that you're not using from the printers option in the control panel, make the Epson your default and check to see whether you've got the latest version of the device driver for this printer installed on both laptops. Also make sure that the printer is installed in a stand alone capacity rather than shared from one laptop to the other.
Apr 12, 2011 | EpsonNet Print Server
Will not stop printing epson c66. four year old was using computer and i have no idea what she did
Clear the buffer by holding down the powerbutton
1) turn off the printer
2) Hold down the power button for 15 seconds
This should stop the printing
Also check your printer que on your pc. Go to printers in controll panel and cancel all print jobs in there too
That should stop the printing
If not you have a defective printer to be sent to repairs.
Mar 19, 2010 | Epson Stylus C66 InkJet Photo Printer
I have an epson tm-t88IV on a USB port it is very slow to react when sent a print job, I did not have this issue with the Parallel Port, is there anything that can be done?
Have you used EpsonExpert.com yet to find the solution?
Go there (it's an Epson site) and set up a free user account.
From what I'm reading, it has to do with using Windows drivers slowing the response and printing. There are drivers on Epson Expert which should solve your issue.
Oct 28, 2009 | Epson TM-T88IV Printer
Whenever I turn the printer on it just keeps printing little weird symbols like one or two lines per page and then goes to the next page and does the same thing just different symbols and it goes on and on...
There is a job in the print queue. At the start of a print job a code is sent saying print the following data as graphics because you have turned the printer off it thinks that all the data is text. You need to delete the job in the print queue. Select the printer in Control Panel>Printers and it should show you a list of print jobs. Delete them
Oct 11, 2009 | Epson Stylus Color 740 InkJet Printer
Printer cacelling job half way through
Try buying a new usb printer cable, just a thought - could have a dodgy connection.... Also - try a different pusb port on your computer.
Steve
www.yourhandinmine.co.uk
Apr 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Dx 4000 - keeps trying to print same document; can't delete it
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
k24674
