The problem you describe is frequently battery related. Make sure that
you have the correct battery type installed, and that the batteries are
fresh/fully charged. If the problem persists, you may have corrosion
on the battery contacts inside that camera that is preventing full
battery power from flowing into the camera. Remove the batteries and
wipe the inside camera contacts firmly with a dry cloth (heavy
corrosion may require cleaning with a wire brush, steel wool, or sand
paper). Remove any residue that may have fallen into the battery
compartment during cleaning, then wipe both ends of the batteries and
reinstall them in the camera. This cleaning solves the problem about
90% of the time, and I hope it works for you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung Digimax S730 Digital
Batterys go dead when not in use-I can take one picture-turn it off--go back in a few hours and the...
(More)
Batterys go dead when not in use-I can take one picture-turn it off--go back in a few hours and the batteries are dead--I'm using rechargeable batterys . Doesnt matter if I use regular or rechargable ones. The only way I have found ot stop it is take the batterys out after each use-then put them back in each time. Thank you for any help. M Clark
i can not start the camera. I have the "select usb computer/printer messege on the camera...
(More)
i can not start the camera. I have the "select usb computer/printer messege on the camera screen but i can not start the camera and connect to the computer
The screen is white, even when I pull out the batteries and memory stick for a very long time. Still...
(More)
The screen is white, even when I pull out the batteries and memory stick for a very long time. Still take pictures, and can transfer them to my PC.
