Question about Westinghouse Dishwashers
There is a slow leak coming out the front right hand side of the dishwasher. How do I stop this?
  • 41 Answers
Check the door gasket on the right hand side. See if it is damaged or not aligned properly. You may need to replace the gasket.
Posted on Sep 13, 2009
Smeg dishwasher leaking from front right hand side, cold leak
The door seal may need replacement, the hot water may soften the seal and fix the leak.
Feb 23, 2015 | Smeg Dishwashers
Coffee pot located on counter directly above dishwasher leaked coffee down front of dishwasher. Heavy light began flashing and will not stop. What can I do?
Actually, I think some coffee got down into the base and triggered the flood sensor. (Or it may coincedentally be that your dishwasher has a leak that triggered the flood sensor). You would have to pull the DW out, remove the panel on the left and right-hand sides, and dry all the water (or coffee) out.
Feb 19, 2015 | Samsung 24 " Built-In Top Control...
Leaking water on the right hand side
Does it seem to be coming from the door it self or from underneath the unit?
If it's coming from the door, check the seal or maybe replace it. It's easy enough and cheap.
(disconnect power before proceeding to the next step)
If it's coming from underneath the unit, first start a cycle to drain it then stop it. Pull the unit out and flip it to its side(have a couple towels ready), then remove the bottom cover and check hoses connects or any signs of leakage.
Feb 23, 2011 | LG 24 in. LDF7810 Built-in Dishwasher
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
I have a cda mx194 dishwasher 1st three lights are flashing and it is beeping it wont start the cycle
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
Jun 15, 2008 | Dishwashers
My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Feb 02, 2008 | Dishwashers
Dishwashers Logo
113 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
