St and lb ?
St and lb ?
st = stones
1 st = 6,35 kg.
lb = ????
1 lb = ?? kg.
Can someone help me with the questionmarks?
Henrik
Denmark
Just type the conversions you need into Google - it will automatically convert them for you
1 lb is 545g
Posted on Sep 13, 2009
What is the correct metric weight for 13 stone.
14 lb = 1 stone
so 13 stone = 182 lbs ( troy )
182 lbs = 67.929 kg
or in ave poy lbs
182 lbs = 82.5 kg
the difference is depending on which country you are in
Jun 07, 2017 | The Health & Beauty
ST KG LB
Stone; Kilograms; pounds. Howzat!
Sep 09, 2012 | Taylor & Digital Scale Lithium Scale
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
EKS bathroom scales Model:8901BM DC:3403 I need to know how to change weight units from Kg's to Stones and Pounds.
Turn the scales over so that you're looking at the underside. You will see a 2-way switch that says "Kg" on one side and "St" on the other... Choose either kilograms or stones.
May 08, 2011 | Home
Hi change kg to lbs
There should be a small switch on the back that allows you to select between kg/lb/stone.
Mar 05, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
What the letters "st" means, this is next to lb and kg
It means "stone": http://en.wikipedia.org/wiki/Template:Kg_to_st_lb
Aug 12, 2010 | Taylor & Digital Scale Lithium Scale
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
