Question about Mitsubishi WT-46809 46" Rear Projection Television
Installing STK392-570 IC's on a Mitsubishi WT-46809
I have a convergence problem on my WT-46809. A previous post informed me that the stk392-570 IC's should be installed on the center circuit board on large heat sinks to remedy this problem. I have inspected the tv to find none of the IC's are labeled STK392-570. How do I figure out which IC's to replace? How many should i order? Your help is greatly appreciated.
-tbmm05
  • zott Dec 14, 2008
    I have the same problem on my tv. The convergence problem is awful. I'm able to adjust the lines right and left but I can't adjust the lines up and down. Anybody have step by step instructions on replacing the ICs. I'd love to salvage this great tv.
  • Anonymous Dec 26, 2008
    I had the same problem with my MITS 46809 TV but all that was necessary was to resolder these ICs. I suppose the heat sink is inadequate and over time the heat degrades the solder. I ordered a service manual, took the circuit board out and resoldered these ICs. I made sure the heat sink had enough thermal compound between it and the ICs. It has been working well now for a couple of years.
  • 934 Answers
Tburg05,
Whoever told you that the WT46809 took two STK392-570 Ic for convergence amps were absolutely - 100% correct... The amps are located at position number Ic8c01 & Ic8c02 on the board. Very difficult to miss too they are about half the size of a pack of cigarettes and 1/4 as thick. They are Mitsubishi part number 267p150010 and after replacing them you want to also check all the low ohm resistors in that circuit for the yoke return.
If you order them don't get them from ebay or some other less than ignorant place, our industry is loaded with chineese knock-offs that would last tem minutes in your set before failing again... Personally I'd order them from Acme Enterprises out of Florida, 800-575-9833 and know that they were Sanyo originals that way.
BTW: If you replace these yourself make sure to use a generous portion of heat sink compound on the new installs for heat dissipation.
Bill
Posted on Dec 11, 2007
Convergence problem in the screen botton i try whith the convergence advance menu but still having the problem.help me please
Replace STK ICs 2 of them STK392-570 Mats has them they big black ICs will have PN# on them.
1-800-628-1118
Oct 02, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Tip
Mitsubishi Convergence IC Part Number List
<b>As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.</b><br /> <br /> <b>Mitsubishi Convergence IC Part # List (complete)</b><br /><br /><br />Ref # / Part # / Part Name & Description <br /><br />CHASSIS: VZ7 <br />MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705 <br />IC8C01 267P141030 HIC-<b> STK392-110 </b><br />IC8C02 267P141030 HIC-<b> STK392-110 </b><br /><br />CHASSIS: VZ8 <br />MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VZ9 <br />MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709 <br />IC8C00 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: VZ6-V15 <br />MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br />MODELS: VS-50800 / VS-50803 / VS-60803 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br /><br />CHASSIS: V16 <br />MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905 <br />IC8D01 267P120010 HIC - <b>STK392-040 </b><br />IC8D02 267P120010 HIC - <b>STK392-040 </b><br /><br />CHASSIS: V17 <br />MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br />MODELS: WS-55908 / WS-65908 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V18 <br />MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V19 <br />MODELS: WS?55859 / WS?55909 / WS?65869 / WS-65909 / WS-73909 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: V20B <br />MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VK20 <br />MODELS: WT-42311 / WT-A42 <br />IC8C01 267P141030 HIC -<b> STK392-110 </b><br />IC8C02 267P141030 HIC -<b> STK392-110 </b><br /><br />CHASSIS: V20 <br />MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: V21 <br />MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: K20 <br />MODEL: WT-42313 / WT-42315 / WT-42413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V22 <br />MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V23 <br />MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 / <br />WS-65813 / WS-73513 / WS-73713 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V24 <br />MODELS: WS-48315 / WS-55315 / WS-65315 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V25 <br />MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250</b>
on Jun 10, 2011 | Televison & Video
Tip
CHASSIS: VZ7
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
CHASSIS: V16
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
CHASSIS: V18
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
CHASSIS: VK20
CHASSIS: V20
CHASSIS: V21
CHASSIS: K20
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
CHASSIS: V23
CHASSIS: V24
CHASSIS: V25
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WT-46809 Powers Off; Code 2-2
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Feb 01, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 rear projection
see if the ics warm up ...out your hand on them if so they getting power.. if cold you lost a resistor or 2.
Sep 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Where to puchase STK392-570 ic
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
Feb 01, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Intermittent color problem
I have the MITSUBISHI WT-46809 46" HDTV CONVERGENCE IC PROBLEM as well. I just ordered the STK392-570 IC for 7 bucks and I am going to attempt to switch them both out (two of them). I am getting the overstated "bow tie", "RBG separation" issue that you are talking about. I am going to attempt to de-solder the intergrated chips and put new ones in. I figure it is worth the shot, insted of paying 350-650 bucks to have some **** with average skills do the same I figure it is better to have this **** with average skills do it and keep the cash. I will let you know how it goes.... DJ
Feb 24, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
3,107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
