Question about NTI Computers & Internet
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
  • Anonymous Mar 29, 2014
    How i downlod CDRW32.BDB?
    How to install cdrw32.bdb?
    Guru:
  • 402 Answers
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Posted on Sep 14, 2009
How can I conform that NTI is working? I can't see changes.
I presume that you are referring to a program produced by NTI, probably NTI Echo, which is a backup program. If so, then be aware that as it is a backup program, it will not delete data from your hard drive but, instead, make a second copy of it (thus the term backup). If what you want to do is use the drive for additional storage so as to free up space on your primary hard drive, then you do not need to use any software whatsoever. Just move the data from the C: drive to the new external hard drive and make it happen.
One suggestion, however: make sure to use directories (aka folders) to organize the files that you move to the external drive. The reason being that the root directory (such as C: or D:) has a limited amount of storage capacity, so just dumping files into the root will cause the hard drive to be "full" despite having plenty of storage capacity remaining. Besides, it will be easier to find the data that you desire if you have it more appropriately organized. ;-)
Sep 25, 2014 | Computers & Internet
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Apr 10, 2017 | NTI Backup Now EZ
Lettore cd-dvd DVD-16X-ROM BDV 316G non viene visto, ciò è accaduto quando ho installato MICROSOFT ESSENTIAL. L'ho disinstallato ma il problema persiste, ho provato MICROSOFT FIXIT, ma...
make sure that the cd-dvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-dvd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 07, 2011 | Microsoft BDV 316G 16x DVD-ROM IDE Drive...
I have already uninstalled NTI media maker; however, there are still remnants, which render my disc drive unusable. (the only one I've found is with auto play there is still an option to use NTI media...
Maybe something on the following page.. as you can see, there can be many causes:
https://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/dvd-drive-wont-work-registry-error-code19/705cf8bc-73e0-49a9-a046-d77a64e68f3a?auth=1
Oct 02, 2017 | Newtech NTI Media Maker 8 Suite for...
Flash drive not opening up properly
Every time you remove the drive - the pc will dismount it - -removed = dismount
when you install it again the pc just sees as a new drive and assigns it the letter it get's by default - this is normal as the pc will mount and give the unit a drive number by default.
It is an inconvenience so I wish you the best.
please vote me up if this helps
Mar 18, 2010 | Computers & Internet
The CDRW driver cant be found
If you go to start, control panel, device manager, cd drive, right click it and click un-install.
Now reboot the system and test.
Hope this helps
Richard.
Apr 22, 2009 | Acer Aspire 3680 Laptop
FILE CDRW32.BDB
This is a driver issue. Try uninstalling the CD drive from the device manager, then reboot. It should find and reinstall the driver properly.
Jul 02, 2008 | Computers & Internet
CDRW32.BDB cannot be found
i think ur cd drive broken..
try to change it..
it will be can fix it..
thanks for using fixya..
good luck...
Apr 24, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
681 people viewed this question
Top NTI Computers & Internet Experts
Tproverb
Level 1 Expert
Mari Criss
Mari Criss
Level 1 Expert
CruzSophia
CruzSophia
Level 1 Expert
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
