Question about IBM ThinkPad T43 Notebook
Boot mgr Is missing on a tobisha laptop
And I don't have a windows/repair disk
  • 109 Answers
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Posted on Feb 04, 2010
My boot mgr is missing on my Acer aspire notebook pc
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Sep 03, 2012 | Computers & Internet
Haveing problems with hp notebook 1100 boot mgr missing error while initializing NIC
Hi There,
I'm having trouble understanding what you mean by this - are you attempting to boot from LAN? Are you able to boot into windows at all?
What it sounds like is that your computer is either missing a boot manager, or you've assigned (in the bios) LAN boot as the priority boot device.
If that's the case, you can change the boot device priority back to internal hard disk in your BIOS (pressing F2 or F10 at startup splash screen)
If you're missing a boot manager for a windows installation, you can insert your windows installation disk and select "repair an existing installation" to repair your boot manager
Jun 06, 2012 | HP Computers & Internet
Boot mgr is missing,also when I try to re program from o/s vista disc after installing updates ,I get the message could not prepare to boot into next stageof installation,restart installation,HELP
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Computers & Internet
Toshiba 5205-S705 is giving an error msg boot.mgr is missing..i tried booting from xp through cd rom but didn work tried to boot with usb as well but didn work any solution pls mail prashantaishu@gmai
bootrec.exe /fixmbr
May 13, 2012 | Toshiba Satellite 5205-S705 Notebook
Boot MGR IS MISSING
What actual operating system do you have?
Windows XP does not use the Boot Manager as this was introduced with Windows Vista or Windows 7 and higher versions.
If you are missing the Boot Mgr for Windows Vista or 7, then you will need to do a Startup Repair which you can do using either a Recovery CD if you have one, or else using the Vista or 7 installation disc.
See the following links:
Windows 7 recovery options
Windows Vista startup repair
Jan 11, 2012 | Microsoft Windows XP Home Edition
When i boot the computer I receive the Boot Mgr Is Missing screen after the bios screen . How do I get rid of the problem.
Insert the Windows disk into the drive and turn on computer. Boot on CD and make a repair from the CD. This should fix the issue.
May 10, 2011 | Computers & Internet
Boot mgr is missing and error code 0xe0ef000e after a fail recovery disc attempt, for a hp pavilion.
0XE0EF000E is an error message and means that the boot sector is corrupt or missing.
Re format the hard drive is the easiest way to recover and then restore your data backups.
Place your Windows install disk in the dvd drive and boot up the laptop. Follow the prompts and if the menu asks if you wish to repair your version of Windows, select that option. It may work depending on how corrupt the system is. You may have to let Windows re format and start again.
Oct 19, 2010 | HP Pavilion dv2000t Notebook
How do i get my boot mgr drive back on my hp dv9000 laptop? I backed up all ym files and when I start my pc up it says the boot mgr is missing.Please help
http://vcic.com/vault/bootme.exe Copy the files to a floppy disk, OR Use a XP/Vista install disk. Boot into repair mode and type "fixmbr" without the quotes.
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Boot Manager
You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
To access the WinRE using the Vista install disk:
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
The following options are available in WinRE:
  • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
    After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
IBM ThinkPad T43 Notebook Logo
188 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
