Question about Nokia N93 Cellular Phone
Failed to get the software registered
I installed Security Shield on my Nokia N 73 but i receive a message that it needs to be registered.how do i do that ? Can it be done via internet? if yes, then how?
Why am I receiving security warnings by AVAST for IDM? I have the current registered IDM installed.
Why having these problems with a virus scanner, if you also can install microsoft security for free. You never need to install anything and Microsoft keeps everything up to date.
Free download:
Microsoft Security Essentials Microsoft Windows
Sep 10, 2014 | Tonec Internet Download Manager
Tip
Nokia Software Updater
Dear updaters, Many of you received the following message when updating their phones "Internal module error". When installing Nokia Software Updater (NSU), very frequently the Microsoft XML4 DLL silent installation crashes. This issue can be fixed by manually registering DLL. Go to Start > Run > enter "regsvr32 C:\WINNT\system32\msxml4.dll" > OK > OK. I hope this helps most of you suffering from this issue.
on Jun 21, 2007 | Nokia N95 Cellular Phone
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to...
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Jan 31, 2011 | Nokia E63 Cell Phone
MY MOBILE IS NOT CONNECTING TO P C ALLTHO PC
its not only pc suite that needs to be installed. You also need to install nokia connectivity driver. This willl install your usb cable.
You can download the connectivity driver from the nokia link below.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-6102i/pc-software/cable-drivers
Also cross-check if your usb cable is well connected to your phone and computer.
Take care.
Apr 22, 2010 | Nokia N73 Cellular Phone
PROBLEM UPDATING MAPS
Plug your GPS into your PC and do not use the Garmin Express program. It will mount as a drive. Delete the maps and software. Then run Garmin Express and do a complete install of the maps and software.
Apr 04, 2017 | Garmin nuvi 255W GPS Receiver
N73
I switched on the phone after couple of hours.phone started working but was extremely slow..then i uninstalled the smobile software.it took much time but it worked.after that my phone started working properly.
Sep 07, 2008 | Nokia N73 Cellular Phone
Security code N 73
u need to concern the nokia care
Aug 13, 2008 | Nokia N73 Cellular Phone
Messages
When you install softwares which are not compatible with your phone , your phone system application such as "Message"will start malfunctioning ....
So just uninstall the any software that you had install
and then restart your cell phone...(If you have no software installed then just try simple restart)
if the problem stills remains the same....
go for "Restore the factory Settings" default security code is 12345
Jun 30, 2008 | Nokia N81 Smartphone
I want software for nokia n 73 call recorder & registeration code
hi,
  go to gallery.mobile9.com..in that u will find n no. of call recorder softwares for nokia n73 free of cost
Thanks
gizmo11
Oct 21, 2007 | Nokia N73 Cellular Phone
Nokia N93 Cellular Phone Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
