Question about Lexmark X4650 InkJet Printer
My lexmark x4650 keeps on getting paper jams and i think its something to do with the roller so any info please help :D
    Brigadier General:
  • 3,614 Answers
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Sep 13, 2009
Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Jan 10, 2008 | Lexmark Optra C710 Laser Printer
The paper wont feed through my printer, it goes in crooked.
IF IT COVER AND MAKE SURE THAT THERE ISN'T ANY PAPER RESIDUE FROM A PAPER JAM. THEN CLEAN EACH ROLLER THAT YOU SEE WITH A DAMP CLOTH WITH A DAB OF DISH DETERGENT.
Dec 07, 2010 | Lexmark X4650 InkJet Printer
Paper jam inside lexmark x 4650 - how to get paper out of machine
If you can't get the paper jam out from the feeder, open the cover to see where the cartridges are. See if you'll have a better hold of the paper stuck in it. Hope this helps.
Jul 26, 2010 | Lexmark X4650 InkJet Printer
Paper jammed in printer. Thought I got it out but new paper just curls and jams too
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Sep 30, 2009 | Lexmark X4650 InkJet Printer
False paper jam message
Look for tiny pieces of paper shreds that might stuck up with the rollers.
Jul 30, 2009 | Lexmark X4650 InkJet Printer
PAPER JAM IN MY LEMAX X4650
Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
Jun 03, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Apr 28, 2009 | Lexmark X4650 InkJet Printer
Printer wont feed paper says out of paper
you "may" have something stuck on one of the feed rollers - a ripped piece of paper or something. See if you can examine the rollers, and look very carefully, particularly on the side that the paper keeps jamming.
In all honesty though, printers are pretty disposable these days. They're not worth getting fixed, and if you can't do quick maintenance on them, getting a new one is your best solution.
Mar 19, 2009 | Lexmark X4650 InkJet Printer
Paper jam how to remove paper when jamed in rollers
First unplug the printer from power chord.
  1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out.
Hope this helps .
Feb 22, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
1,130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
