Question about Sony Televison & Video
Please,display not working on sony surround remote control RM-LJ304
    Top Expert:
  • Sony Master
  • 53,162 Answers
Probable failure
Posted on Aug 15, 2019
SOURCE:
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Posted on Jun 19, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
welcomejee
  • 10594 Answers
SOURCE: av 1 stuck on sony tv screen
Press Display / " i " Button on TV remote, on-screen display will disappear.
Posted on Jan 26, 2009
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
Remote contral not working
Check it with fresh batteries. Check the battery contacts in the battery compartment for any rust or dust accumulated, which prevents the proper electrical contacts. Clean them well and check.
Dec 24, 2012 | Sony RM-LJ304 LCD Remote Control
Tengo un control de sony RM-YD014 quiero el manual o el codigo para programarlo otra ves a mi televizor
REMOTE CODES & PROGRAMMING INSTRUCTIONS RM-YD014 The RM-YD014 remote control is not programmable and remote codes are not required. This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. Please note that this remote may not be able to control all models of these other Sony product types.
Jun 12, 2012 | Sony RMYD014 Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Batteries leaked, cleaned as best I could, but doesn't work! removed two screws to access inner panel, but it wouldn't open. (I hoped to clean further}. with fresh batteries, I've tried to turn on my amp,...
If you have had a battery leak then this is a very bad thing. It's possible that the battery acid could have corrupted the system board in the remote. I would call Sony to see if they have any suggestions for you, however I think you may end up needing to replace the remote.
Jul 13, 2009 | Sony RM-LJ304 LCD Remote Control
Sony DA50 display reads UNLOCK. Will not play in 5.1 surround.
What type of DVD player do you have? I had the same problem with my Sony bdp-s1 bluray player. You might have to go into your menu on your player and set it up to decode the 5.1 signal.
Mar 02, 2009 | Sony RM-TP501 Remote Control
Av 1 stuck on sony tv screen
Jan 26, 2009 | Sony RMT-833 Remote Control
Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Televison & Video Logo
15 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
