Question about Toyota Computers & Internet
My Toyota corona engine 3s D4 stops running in motion and mixes fuel with oil
What makes it to do that
    Master:
  • Toyota Master
  • 587 Answers
It can happen in a couple of ways, depending on your engines design. A leak from the fuel pump into the oil pan is one possibility. A cracked cylinder is another possibility.
Posted on Aug 19, 2019
SOURCE:
SOURCE: Toyota ardeo 3S-FSE D4 2.0L
How do you adjust idling on a toyota 3s-fse engine
Posted on Dec 12, 2010
wencal1963
  • 153 Answers
SOURCE: i have 3s 2000cc corona
PUT 4QTS IN CHECK FLUID LEVEL IF CRANKCASE IS COMPLETELY EMPTY . MAKE SURE ENGINE IS OFF. THEN FILL ACCORDINGLY TOO FULL LINE . USALLY MAX IS 5.0 QUARTS. NEED TO KNOW YEAR OF VEHICLE.
Posted on Jan 14, 2011
SOURCE: which engine fits my 1998
Jus check an auxillary air valve if it is working.if not jus bypass the pipes,the car will be fine.
Posted on May 23, 2012
nobody322
  • 20706 Answers
SOURCE: The speedometer on my 1998 toyota D4 corona premio, 3s engine, suddenly drops when i step on the accelerator with the intention of increasing my speed. when i try to speed up the vehicle almost stops
GAS
3s-fse-d4-engine???? 3s-GE OR GE WITH RED BEAM? "VVT"
M./T OR A/T (STICK OR AUTO)
the key factor is engine RPM
if it rises, but not speed, that is trans./clutch slip
if no rpm rise that is weak engine , BUT IS THE RED BEAM.?
LOW POWER, 101
1: NEVER TUNED UP. BAD SPARK CLOGGED FILTES X2
2: ENGINE ecu stuck in limphome, scan it, see errors, BINGO
3: engine misfiring, cause by low compression, weak spark or bad fueling (too rich or too lean) many tests, ask.
4: low fuel pressure or regulator not regulation per FsM PAGE
5:STUCK OPEN egr main valve (missing in some countries)
6: melted cat converter , vacuum gage reads real bad,
7: and more, i charge more for more, LOL vvt?
ask or tell?
i want wild guessing
or I want to do the tests. to find it.
Gue$$ or Test.
toss coin.?
Posted on Jan 08, 2015
watsonhellas
  • 774 Answers
SOURCE: How do I fix...?idling and revving problems on Toyota d4 petrol engine 3s
There are several issue and modern ECMs are complex. You need to get a fault code reader, tell us the codes and we can help you sort it out. Could be EGR, idle sensor or idle control valve, speed sensor, or a simple cleaning of the throttle body with carb and Choke cleaner... don't spray the sensor.
Posted on Mar 21, 2015
Toyota vista d4 engine runs then shuts after a while drive.cools down then starts again.3s-fse
It seems somebody tempered with the throttlebody air adjustment so whenever the car heats up they will be more air supplied to mix with fuel it blows the fuel out plus the heat coming makes the car does what we call preignition rendering the cylinder useless at the point of combustion but after it cools down with the air switch automatically switched off for cold start it will run
Sep 04, 2016 | Toyota Cars & Trucks
What causes oil and petrol to mix in toyota nadia D4. How can i prevent the pump from failing. Fuel consuption too high
The only thing that let's fuel into oil is when your cooling system malfunctions it will make the D4 pump seal to be hard and cause it to crack.making the car run out of fuel can cause the D4 to malfunction.do not add injector cleaner in to your petrol on car with D4 pumps it opens 4th he nozzles so they end up dribbling that produces a black smoke
Jun 28, 2016 | Toyota Cars & Trucks
How do I time a 3S d4 Toyota corona engine?
i moved you out of JEEPS
its not a JEEP
new year, car.
fail 2 times.
books start with year, see?'
online or real.
same.
Jan 28, 2016 | Toyota Cars & Trucks
My nadia 3s D4 mixing oil with fuel
It's the D4 pump that is making your oil level to rise and makes the car fail to run
Nov 22, 2015 | Cars & Trucks
The speedometer on my 1998 toyota D4 corona premio, 3s engine, suddenly drops when i step on the accelerator with the intention of increasing my speed. when i try to speed up the vehicle almost stops but...
GAS
LOW POWER, 101
ask or tell?
Gue$$ or Test.
toss coin.?
Jan 08, 2015 | Toyota Cars & Trucks
My vehicle toyota corona D4 egine 3s turns off while driving, please help know what could be the problem
my 2005 toyota caldina d4 engine shut off while driving, i change crank shaft sensor, fuel filter, injector driver, air sensor,
May 09, 2012 | Toyota Corona Cars & Trucks
Which engine fits my 1998 Toyota Corona Premio D4 as i would like to change the current 2.0 3S engine to a more economy engine.
Aug 15, 2011 | 2001 Toyota Corolla
Computers & Internet Logo
19 people viewed this question
Top Toyota Computers & Internet Experts
STEVE
Rob Woolcock
Rob Woolcock
Ngoro
Are you a Toyota Computer and Internet Expert? Answer questions, earn points and help others
