Question about Timex Watches
How do I set the alarm on the Timex T235 - Timex Watches
    Top Expert:
  • Timex Master
  • 1,757 Answers
Setting The Alarm Time
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the POWER/MODE button until the display briefly shows 'OFF'
and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the TUN + (HOUR) button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is 'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the TUN - (MINS) button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM1 button once more to confirm the wake-up time setting or after 8 seconds the display will stop flashing and the new wake-up time will be entered automatically. The display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. The Buzzer indicator will turn on. Press the ALM1 button once more to select the Radio alarm. The Radio indicator turns on. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
https://cdn.timexaudio.com/media/product/files/T235_User_Manual.pdf
Posted on Aug 14, 2019
SOURCE:
How do i set vibration on alarm on expediton watch
Janice, set vibration alarm to on expedition watch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Enable Vibration Mode for Alarms on Timex Expedition W214 Wristwatch
https://answers.yahoo.com/question/index?qid=20111002092048AADRLYs
http://www.timex.com/info/watch-manuals
Aug 18, 2016 | Timex Expedition Watches
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
May 04, 2012 | Timex Expedition Watches
I have a Timex Wacky Wake-up Alarm clock and can't
When you are setting the alarm on the wacky wake-up timex alarm, if you keep pressing FWD, you will see a small PM in the bottom right hand corner. When the PM sign is gone, you will now that it is set to AM.
Mar 09, 2012 | Timex Watches
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
Need two timer alarms.
My reading of the instructions is that the answer to your question is "NO".
See the section on "Alarm". This indicates that there is no repeat function that you require.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 26, 2010 | Timex T5E501 Ironman Triathlon Sleek 50...
How to set alarm on easy set alarm
At the
manual download"
Feb 08, 2010 | Timex Expedition 84601 Wristwatch
Need to turn off alarm
A model would be most helpful here. Timex has a couple different alarm set ups.
With most of their watch if you cycle through the modes using the mode button you will come to alarm. Depress set and the alarm will toggle on or off.
With Dial alarm models you simply depress the alarm button (the one with the red stripe).
Sep 18, 2009 | Timex Watches
Alarm set
You may find a solution here:
http://assets.timex.com/manuals/?timexBrand=core
Rate me, please.
Apr 03, 2009 | Timex 1440 watch
Setting Alarm
Here is a link to an owners guide for a Timex reef gear. It should help with setting the alarm. Good Luck!
http://assets.timex.com/instructions/085Instr.pdf
Feb 16, 2008 | Timex Reef Gear 53572 wristwatch
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Watches Logo
22 people viewed this question
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
