Question about LG Washing Machines
LG LFX25976ST leaking water on floor - LG Washing Machines
Lg front load washer drain hose out ot machine leaking
IF it is leaking on the floor, the hose may be damaged or cracked. Since you did not post the model number, it is hard to say what the next step is.
Mar 18, 2018 | LG Washing Machines
My lg refidgerator modle lfx25976st it runs but doesnt cool or freezer wont
Check for a bad hard start cap/relay on compressor. If it is running check for ice on evaporator - if ice then the defrost mechanism is not working.
Aug 27, 2017 | LG Refrigerators
Water leaking on the floor from back of my lg 25975st
The water supply lines could be leaking or loose. The fill valve could be leaking.
Aug 07, 2016 | LG Washing Machines
Squeaky seal on lg french door
Just get some wd40 and spray the inches, as they have gone dry
Feb 16, 2014 | LG LFX25976ST 24.7 Cu.Ft. French Door...
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Apr 01, 2013 | U-Line Refrigerator Ice Maker
Ice maker stopped working in lg refrigerator lfx25976st/00
I just slide the ice tray to the left and down till it unhooks from the right hand side. Then unhook the wires from under the tray. To replace just repeat in reverse order. I have to take our ice tray out ever so often to clean it since we have well water.
There is a little square button up under the left hand side in the back. If you press that with a screwdriver or butter knife it will reset the ice tray and it return it to fill with water.
Sep 03, 2012 | LG Refrigerators
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
56 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
