Question about Gucci Watches
I have a Gucci watch with the model number 3605 L on the back but I don't see a serial number how do I find out if its real
    New Friend:
  • 10 Answers
Open it up and see what movement is inside, Gucci Buy their movements, as they are NOT watch makers but a fashion designer. I would expect to see an ETA automatic 2836/2 or similar. The ETA is a Swiss made movement, ETA supply movements for many good watch brands, such as Tag Heuer, early Breitling, Raymond Weil, Fortis, Ebel & the list goes on. Very easy to work on and spare parts are easy to obtain. Great work horse movement is the ETA, hence why everyone else uses them, not just Swatch.
Not sure your watch would have a serial number, not all watches have them. Just because you can’t see one or it doesn’t have one, it doesn’t mean it’s fake.
If you pop the back off, take a photo of the movement and send it to me at [email protected] or if you can place it on here, do so, but I’m guaranteed to see it if you email it to me.
Gucci watches are around £400/£600 range, so should be a good solid watch.
Does it sound solid when you shake it? It shouldn’t squeak or rattle too much at that money. The crystal should be AR coated (anti reflective)
Also use a magnifying glass to look at the dial for imperfections, there should be none. QC at Gucci is tight, so look carefully at the dial.
Hope this helps
Posted on Aug 15, 2019
SOURCE:
VOTIT
  • 2071 Answers
SOURCE: is my cartier watch real or fake
You can distinguish real or fake.the real is heavy than the fake,fake is lighter.the color the real one is not to shine is dull,the fake is very shiney compare to real,the metal they use the real uses stainless,titanium and gold.The fake is nickel plate or zinc metal.the engraving the real is deep seated engraving,the fake is on the top only not so deep.I can't say your watch is real or fake,basing on serial number,the emitator can emitate the number.I gave you a tip how you know the real or fake.
Posted on Jun 17, 2008
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Posted on Jul 25, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
SOURCE: is this a real or fake serial number E56121.1
Not true, it is real, I've got the same breitling and I know it's real. It's an emergency watch generally used by military personnel.
Posted on Dec 08, 2009
gemineye61
  • 831 Answers
SOURCE: I have a movado watch the serial number is 84 e7
As with luxury bags, luxury watch brands such as Movado are copied and sold illegally. Movado watches are popular among both men and women, but sellers of replica watches hurt the brand by providing the buyer with poor craftsmanship. Dealers know what genuine Movado watches look like, and they are familiar with the watch model names and numbering system. While you can take your watch to a dealer to closely inspect its authenticity, you, too, can learn how to tell if your Movado watch is fake by noting a few details.
Check the material the watch is made of. Replica watches are made of aluminum, and they don't have the same heavy weight of an authentic Movado. Movado watches should feel like quality, solid pieces. True Movado watches are made of stainless steel.Observe the movement of the watch. The movement of the second hand should not be erratic or shaky. It should look smooth as it travels across the face of the watch.
Look closely for scratches on the glass face. Movado watches are scratch resistant, so any imperfection on the face is a telling sign that it's fake. Hold the face to the light and observe if it gleams like a genuine watch. If it's dull or cloudy, it's not authentic. Also, look for the inscription "Swiss Movado Made" to make sure it's authentic.
Feel the links and the clasp on the watch. Clasps should feel solid, and the links should be joined together by screws. Gently pull on the clasps and check for any loose pins. If the clasps feel fragile, it's probably fake.
Posted on Jul 26, 2010
Have a gucci watch not sure of model but have serial no
Most authentic Gucci watches have the model number on the back. If you see nothing but a crest, or a crest and the Gucci name, the watch is likely fake. No authentic Gucci watches display just the crest and name without additional markings.
Oct 05, 2017 | Gucci Watches
I want to confirm og gucci lady watch serial number 1846.that is it orginal or fake
search online for the gucci watch site real of fake watches
Mar 31, 2017 | Gucci Watches
Is my paolo gucci watch fake? the serial number is PG492TS
Serial numbers can be just as fake as the items themselves. Only a qualified jeweler or watchmaker can validate your question and then only if you present the item for inspection. Many people buy these items online or in non-certified auction settings and get a "great deal" on them. Most find out they have fakes. Real quality items aren't just given away 99.9 percent of the time. There are many out there just looking to scam the unwary buyer who thinks they are getting something on the cheap. You may have a real one, but no one can tell you that online via text or even with a photo. Only the real deal with a professional who knows the product can validate its authenticity.
Jul 14, 2016 | Paolo Gucci Watches
Hi i found gucci bangles watch in olx online with serial nos 1204424.is this original or no..thanks
Sorry Marivic Claves,
There is ABSOLUTELY no way to tell if a watch is "real"
from the number on it... You should take it to a dealer
to get it properly authenticated.
(if some-one went to all the trouble to replicate a watch.. why would they not replicate a good number?)
Hope this helps!
Jul 05, 2016 | Gucci Watches
My Gucci serial number is 10860032 is it fake or original
Bobo, contact Gucci. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gucci Official Site United Kingdom
Top 10 Tips to Identify Fake Gucci Watches
The difference between real gucci and fake gucci
May 02, 2016 | Gucci Watches
Can a serial number on a Gucci watch be checked for authentication?
Hello, I've just read here: http://www.ask.com/beauty-fashion/check-gucci-serial-numbers-a0287af75d5c1830#full-answer
that Gucci's Customer Service should be able to verify the serial number. The main customer service number is: 1 (877) 482-2430
Mar 28, 2015 | Gucci Watches
Gucci watch serial number check
Hello, Gucci will be able to verify the serial number on their customer service line: 1 (877) 482-2430
May 12, 2014 | Gucci Watches
Identify my watch with serial number
where can i find the serial number on my gucci watch 1500?
Sep 01, 2012 | Gucci 1500 Watches
Watches Logo
23 people viewed this question
Top Gucci Watches Experts
Arturs Kalnins
Arturs Kalnins
NOEL
NOEL
Ngoro
Are you a Gucci Watch Expert? Answer questions, earn points and help others
