I have a TC-P60ST50 and the whole right side went completely black. Its about 1/3 of the screen. Is it fixable?
SOURCE:
trintek
  • 111 Answers
SOURCE: panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
SOURCE: shadow on right side of screen
Shadows on the left or right (if the projector is ceiling mounted) of the projected image area has nothing to do with the DMD it is the light tunnel tha is at fault. See other posts about this problem.
Posted on Dec 31, 2007
  • 138 Answers
SOURCE: The whole screen is shifted 1 inch to the left.
When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
Posted on Aug 20, 2008
kb8dns
  • 494 Answers
SOURCE: Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Posted on Feb 15, 2010
SD Tech
  • 14553 Answers
SOURCE: LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Posted on Mar 25, 2012
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
The right side of our screen keeps going dark, almost black. Once I tapped the side of the tv and it popped back to normal. Sometimes it goes back to normal by itself. It is black most of the time though....
Yes usually fixable unless its the panel goning bad. What if you squeze the panel where the black bar is does that effect it. If so the cabinet is probably bowed. Hope this helps.
May 25, 2011 | Sanyo Televison & Video
Feb 15, 2010 | Sony Televison & Video
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Installed xp upgrade it won't use the whole screen
Hi ABIDJAN,
Upgrade the video drivers or adjust the setting on the monitor.
Good luck.
Jul 27, 2008 | HP Compaq 6510b Notebook PC
LCD TV Screen repair
I have a Sharp LC52XD1E TV , It has a crack on the screen needs a new screen can it be fixed and is it worth the repair?
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Ekse
