How to get tv to change channels when mash channel changer it says not available?
    New Friend:
  • 36 Answers
Go to tv settings and do a channel scan. This should fix the problem. If not then hope is still in warranty.
Posted on Aug 14, 2019
SOURCE:
techman
  • 3130 Answers
SOURCE: channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Posted on Sep 18, 2006
SOURCE: Sanyo TV is stuck on Video screen
You need to get a universal remote with imput button on it. the imput button will control wether you want to use video or channels.
Posted on Sep 24, 2007
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Posted on Jul 26, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Posted on Mar 20, 2009
  • 89 Answers
SOURCE: Tv won't change channel
did you hook the tv up to the converter box or did you not add channels?
Posted on Aug 05, 2009
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Lost over half of the cable channels. How do I get them back?
set in air band, you want catv or cable band.
Aug 27, 2012 | Orion1934 19" TV
Tuner appears to be stuck in channel 4. Cannot change Channel.
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
Jan 03, 2011 | Panasonic CT-27SL14 27" TV
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Sharpe LCD TV...model LC-195K24U-K...can't get to change channels
what causes a line down the middle of my screen
Jun 08, 2008 | Televison & Video
TV channels
Sounds like it lost programing, if it has an "auto program" feature try that, or some older models need it to be done manualy and have a "add/erase" feature, instructions for that should be in your owner's manual.
Oct 31, 2007 | Televison & Video
Oct 15, 2007 | Televison & Video
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
Aug 24, 2007 | Sharp 13VT-K100 13 in. Combo
Channel selection
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Ekse
