CPU switches on when mainwall plug switched on, on/off switch on cpu not operates. Can I change this?Is there a jumper to change?
    Genius:
  • 1,027 Answers
I suspect that the case front on/off switch is not connected to the proper pins on the motherboard. If the motherboard's power activation pins are shorted, then it starts every time on applying AC.
Posted on Sep 13, 2009
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the connections. When we turn on the computer all the fans start and all the...
check the cable connections initially
Remove the power cord from the cpu
Remove the cmos battery and reset the bios by changing the jumper which is present to reset bios in motherboard.
Place the jumper as if it was present already
Insert cmos battery and switch on the computer
Mar 04, 2010 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
I reset the CPU but now I get nothing on the screen. Could I have fried the CPU?
open your case and on the motherboard near the battery ther is a three pin jumper the jumper is on 1and2 change it to 2and3 leave for 10 seconds then put back onto 1 and 2 ,make sure your system is switched off before you do this, boot her up and it should start up go into your bios by tapping delete when booting up and reset date time , dont clock your system unless you know what you are doing, good luck.
Dec 14, 2009 | Abit IS-10 Motherboard
Green light comes on but wont power on
Remove the battery. Try again. If the PC starts, change the battery.
Nov 05, 2009 | ASUS P4B266 Motherboard
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
CMOS bad message being displayed
what you should do? here is what you do.....a simple idea....replace the CMOS battery and 100% it will work good...it will not bugging you everytime you open the pc....check,i need to share only my experience.
Mar 03, 2009 | Intel D845GVSR Motherboard
My Mb does not give any sign, . What can I do ? Everything is desconnected except power on the Mb and the Mb switch. I switch the machine on and the only thing works is the CPU fan No any beep
Sometimes you have to have the motherboard , power , cpu , memory and 1 drive connected (IE the basic components) to get the system running
Also check the jumper settings where the board connects to the power switch on the case
Jan 22, 2009 | ASUS P4SP-MX Motherboard
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
Upgrade my computer procesor
Socket type: mPGA478 (P4).
P4 – 1.4-3.4 GHz
P4 EE 3.2-3.4 GHz
MOTHERBOARD MANUAL: http://www.elhvb.com/mboards/OEM/HP/manual/danube_manual.pdf
It shows you how to take off and put in the CPU.
This is a guide on how to install the CPU/with FAN.
http://www.pctechguide.com/tutorials/Pentium4_CPU.htm
Nov 11, 2007 | ASUS P4B266 Motherboard
CHANGING CPU'S TYPES AND SPEEDS
On these old motherboard there is usually one switch that is used to change the CPU type - from Slot to Socket, in this case. But there are usually a different set of jumpers that control the CPU speed. And usually another set to control the bus speed, assuming it supports more than one. In this case it might support 100 or 133, depending on the CPU.
In some cases, you can set the jumpers to "AUTO", which automatically selects the bus and CPU speed. This was only available on the higher end, newer and more expensive boards.
Nov 07, 2007 | Pc Ware M748LMRT Motherboard
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
