Washing machine says door problem even though door is shut hotpoint aquarius wmf 740
  • ianforbes1 Sep 13, 2009
    should the door switch lock the door electronically
  • 999 Answers
The door switch is no longer making contact internally or a wire has broken r disconnected. I would verify this with a test meter and replace the switch. Eric
Posted on Sep 13, 2009
  • Eric Duda
    Eric Duda Sep 13, 2009
    The lock only activates when the door switch is closed by the door latch. It requires the conformation the door is closed before it trys to lock it. It will require careful diagnosis of the door latch/lock assembly. Eric
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
Hotpoint aquarius 7kg wmf 760 washing machine door wont open
the pump filter is blocked you need to pull the washer out and tilt back the door should open but there will be water in it unblock the filter should be ok
Nov 29, 2012 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
May 23, 2012 | Hotpoint Washing Machines
Do i have to use some kind of limescale prevention detergent in my wmf 740?
Use a product called "AFFRESH".
You can also use white vinegar.
Pour in one quart and set the cycle to Wash.
Aug 02, 2011 | Hotpoint Aquarius WF000 Front Load Washer
How do I remove the drawer from my Hotpoint aquarius WMF 540 to clean it??? x
Open the drawer, lift or push it upwards, and pull it out towards you.
You should now be able to clean it.
Please rate my solution.
Thankyou.
Jan 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
614 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
