Question about Canon PIXMA MP600 all-In-One InkJet Printer
I get the U043 error on my Magenta. Cartridge is set properly.
Any other ideas ?
  • 33 Answers
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Posted on Sep 13, 2009
  • olenielsen Aug 27, 2011
    My PIXMA 630 cannot recognise any of my recently bought C-221 cartridges.
    The ones I have are labelled CLI-221. Otherwise they look exactly the same. What is going on?
Canon mg5350s u043 error
Easiest solution is to buy an original cartridge, any colour and this will normally reset, otherwise your Google the problem and you should find a solution to disable this function, but chaeck reguarly as you wont get a warning that the cartridge is empty after you disable the function
Jul 15, 2014 | Canon PIXMA Office Equipment & Supplies
Does not recongnize ink cartridge
Make sure you've removed the protective tape from the cartridges that you inserted into the printer and that the cartridges were installed properly. Are you getting an error message or is the printer just not printing? If you get an error such as Error U041 or U043, the printer may just be low on ink or have a bad ink cartridge.
Oct 19, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Brand new magenta cartridge cannot be recognized U043
a brand new magenta cartridge cannot be recogined for a HP 3310 printer
Aug 02, 2009 | Canon Pixma MP800 All-In-One InkJet...
Keep getting a U071 error message for cartge Y
Open the printer cover and check to make sure only one Yellow cartridge is installed. If so, try the following:
Remove each of the other cartridges, one at a time as necessary and see if the error message changes. Start by lifting the cover, then wait for the printhead to move to the left so you can access the cartridges inside. Pull out one of the other cartridges ( not Y) by pushing its front tab back then close the cover. Check the display, repeat as necessary. The error should have changed to U043 (bad or missing cartridge) once you remove the bad cartridge. When you replace it, the printer should work. My guess is the Magenta or Cyan cartridge is causing your error.
Apr 14, 2009 | Canon Office Equipment & Supplies
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
When i Put in PG5Black I get an error message U043. Help
most likely a faulty Cartridge, try a new one,
otherwise it will be a faulty internal component(cartridge contact, mainboard or carriage assembly) will need service
May 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Nov 14, 2007 | Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,277 people viewed this question
old marine
old marine
