Question about Alessi MG32 Cordless Electric Kettle
Kettle will not stay on
The switch on the kettle will not stay up unless I apply downward pressure to the kettle, ie press it onto its base. When I release pressure, the switch goes off again.
    President:
  • 3,433 Answers
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Posted on Sep 13, 2009
It beeps and the temperature light comes on but then it immediately fades and the kettle does not heat up.
I had the same problem after 2 years usage and found the problem to be the contacts between the kettle and base.
  • Unplug the base and using a very thin needle file clean the 3 contacts and centre pin carefully. These contacts are sprung metal, so be careful to apply slight pressure in a clockwise direction.
  • Next empty and upend the kettle, now use a fine abrasive pad (I used a piece of 'wet and dry' paper) and gently clean the surface of the contact rings.
  • Clean away all dusty residue, this should cure the problem.
Jan 13, 2016 | Bosch Styline Collection Kettle Twk8633gb,...
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
I have a dualit 72402 kettle which is not heating,when put on base, switch will stay down and neon lights possibly the element has gone but I cannot unscrew base of kettle to check it,do you sell this tool...
I have a similar problem and spoke to Dualit who say that the element is probably blown. As the unit is sealed into the base it is not repairable and should be scrapped. Not really a solution more a way forward
Feb 17, 2010 | Dualit (7202) Cordless Electric Kettle
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
On Off switch problem
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Jul 08, 2008 | Russell Hobbs RHOK3123 Cordless Electric...
Siemens porsche kettle om switch problem
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Feb 04, 2008 | Kitchen Appliances - Others
Switches off before full boil
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Alessi MG32 Cordless Electric Kettle Logo
528 people viewed this question
Top Alessi Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Bill Boyd
Are you an Alessi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
