Question about Tomtom Go 630 GPS Receiver
When I switch on my device I get a flashing white "X" in a red circle. The small picture of the hard drive[?] also appears on the bottom right of the screen. I have tried re-setting several times to no avail. I have pressed he re-set button for > 10 seconds, then the on/off switch and the re-set together. If I press the reset very quickly many times I get a black screen with basic data. But the problem remains. The device is unusable.
  • alan_hannah1 Sep 14, 2009
    Dear Mr Kumar,
    Thank you for taking the trouble to try to sort out the problem, unfortunately it did not solve the problem. I located Customer Support at TomTom UK and got the following advice. [Note I have an iMac and the Spotlight function should be disabled]:
    "Thank you for your call today.
    Please follow the steps below to reinstall your software and resolve the issue. We appreciate that this may look a little bit involved, but the steps below are necessary to cover all eventualities.
    STEP 1 Install the latest version of TomTom Home
    If you haven't already done so, please download and Install the latest version of TomTom Home from http://www.tomtom.com/services/service.p...
    STEP 2 Make a Backup
    - Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
    - Open TomTom Home
    - Click on 'Backup and Restore -> Backup' in TomTom Home 2.7
    - Proceed with making a full backup of your device.
    - See http://www.tomtom.com/3171 in how to do this also.
    IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in Step 2. If you are unable to complete step 2, please reply back to this email and let us know what happens.
    STEP 3 Run a Disk Error check
    - Click Go on the top menu bar
    - Click Utilities
    - Double Click Disk Utility
    - Click on the disk for your TomTom
    - Click Repair Disk
    - Then close Disk Utility
    STEP 4 Delete the Application Files
    - On your desktop, you will see the TomTom disk here, please click into it.
    - You will see a list of folders and a list of loose files
    - Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
    STEP 5 Delete the Downloaded Program Application file on your computer
    - Open TomTom Home 2.7
    - Click on ‘Manage my GO/ONE -> Items from My Computer’
    - Tick the option for ‘Applications’
    - Click on ‘Remove Selected Items’
    STEP 6 Update Your Device.
    Next we will reinstall the application via TomTom HOME.
    - Open TomTom Home
    - TomTom Home will check for updates. If not, click on 'Update my Go', or 'Update My One'
    - In the list of updates, you will see a 'Program Application'.
    - Deselect all other updates that may appear then click on 'Update and Install'. This will download and install the program application update.
    - Please repeat STEP 6 until no further application updates are offered.
    - Once complete, Click on 'Device -> Disconnect Device', then turn off your device and disconnect it from your computer.
    - Switch the TomTom on.
    - The device should load up to the map screen."
    President:
  • 1,462 Answers
First turn your firewall off (if you have one).
You need to go into your 630 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 630 ,
Bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 630 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button,
when done, go back and to device (option in top of your screen) and select disconnect device, restart your 630 and it should be back to life with the upgraded software.
Hope this Should solve your problem else Call their tech support at no charge (866-486-6866, Glen) , really good service
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 13, 2009
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
One red light flashing bottom right of the circle no pic or codes
Take a huge hammer and smash the light into pieces. There you go, no more red light...
Dec 25, 2008 | Microsoft Xbox 360 Console
TomTomGO
youll need to reload the firmware
that should fx it
Aug 28, 2008 | Tomtom GO 910 GPS Receiver
TomTomGO
hello, The CD symbol in the corner is to show that the internal hard drive has a problem searching for or loading files. If your lucky your hard drive will be OK but somehow you have lost or corrupted data. If you made a backup copy of your hardrive sometime in the past then now might be a good time to reinstall that backup. If your'e unlucky then your hardrive is shot and the only answer will be to replace the drive. This can be done at reasonable cost by obtaining one from a defunct MP3 player or similar nano , Ipod type that has a suitable microdrive. Scrapper types of these can be found littering Ebay , but of course keep in mind the risk that these too could be damaged. Good luck , hope it all works out for you.
Aug 27, 2008 | Tomtom GO 910 GPS Receiver
After switching on the device a picture of a tom tom sat nav comes on and a flashing white x with a rounded red background. This is as far as the switch on goes
there is a reset switch on bottom of unit a small hole that you need to insert a paperclip or pin in and hold for 20 to 30 seconds that may work
Dec 22, 2007 | Tomtom GO 700 GPS Receiver
Tomtom Go 630 GPS Receiver Logo
258 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
