Question about Sentry Fireproof Safe
My code no longer opens the safe for some reason. it is approximatelly 3 yrs old. It is a digital key pad. Is there a battery that I need to change?
  • Anonymous Mar 25, 2014
    First Alert Digital .62 cubic feet 2073F----Aoo1 0610YH73 Cannot open with key pad or key
    Brigadier General:
  • 4,090 Answers
Contact Sentry Safes
We are not able to provide any information legally about opening safes
There is no way of knowing if you own the safe or have any rights to open it, to assist you would leave us open to being complicit in a possible crime.
Thank you for using FIXYA
Posted on Sep 13, 2009
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    How do i set code for paragon safe
    INITIAL BATTERY INSTALLATION
    1. Remove the key plate cover, insert the key into the keypad and open the door.
    2. Remove the battery cover plate located on the inside of the door.
    3. Install 4 AA batteries provided and replace the battery cover.
    NOTE
    : If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
    to be changed.
    TO SET UP OR CHANGE A USER CODE
    1. With the door open, locate the red button on the back of the door near the hinge.
    2. Press the red button and listen for the beep.
    3. Immediately enter your new passcode (3-6 digits long)
    4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
    NOTE:
    This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
    first passcode entered.
    SETTING UP OR CHANGING A MANAGER PASSCODE
    1. Open your safe with the passcode you wish to change and leave the door ajar.
    2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
    New user passcodes may be 3-6 digits long.
    3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
    OPENING THE SAFE
    1. Input your code and then press the "B" button, the green light will turn on.
    2. Turn the knob clockwise within 5 seconds to open the door.
    3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
    flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
    CAUTION
    : Entering the incorrect passcode 3 times will lock the system for 20 seconds.
    More information can be found in the attached document web page.
    http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
    Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
    I have the key I know the3 combination but still i could not open because it's in low battery
    if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
    Jan 03, 2013 | Safe International Digital Electronic Safe...
    Just put new batterys in safe . but safe will not stop bleeping what is the problem
    Please follow these steps
    Programming a user code
    There are two ways to program a user code.
    A 1. Press the Program key.
    2. Enter the Factory Code. The green LED remains ON
    while you enter the 5-digit user code of your choice.
    After 5 digits are entered the green LED turns OFF.
    (To enter a new User Code, repeat these steps.)
    B 1. Press the red button inside the safe. The lock will
    beep and the green LED will come on.
    2. Enter a 5-digit user code.
    Keep your new user code secure.
    For your records, please copy it here:
    ____ ____ ____ ____ ____
    Programming a password
    2. Press it a second time.
    3. Enter your 5-digit User Code. The green LED remains ON.
    4. Enter the 5-digit Password of your choice (any combination
    except 00000.) After 5 digits are entered, the green LED
    turns OFF.
    (To enter a new Password, repeat these steps. To erase the
    Password, press Program twice, enter your User Code and then
    enter 00000.)
    Battery replacement
    Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
    reestablish your Password, follow the directions above under
    Programming a Password.
    Key override
    If your electronic lock fails or you do not have any codes
    available, you may use a key override to access this unit.
    1. Remove the battery cover, disconnect and remove the
    battery holder.
    2. Insert the skeleton key (second set of keys provided)
    into the key hole inside the opening for the battery.
    3. Turn the key to the right.
    4. Turn the four bit key to the right.
    5. Open the door.
    Signals
    Your electronic-lock safe communicates by means of several
    audio/visual signals.
    Red (Error) LED + three beeps indicates
    one of the following:
    1. You have pressed Program key out of sequence
    2. You have entered an invalid code or password.
    3. You have let 5 seconds or more elapse between key entries.
    Green (Proceed) LED + single beep occurs
    1. After entering each digit of Factory or User Code, or
    Password
    2. After pressing Clear key
    3. After pressing Program key
    Green LED only
    1. Comes on after you enter a valid code/password and
    remains lit during the 4-second period in which the safe
    can be opened.
    2. Comes ON in the Program User Code mode after you enter
    the Factory Code and remains lit until you have finished
    entering a 5-digit User Code.
    3. Comes ON in the Program Password mode after you have
    entered your User Code and remains ON until you have
    entered a 5-digit password.
    Yellow LED
    Indicates low battery and will typically not turn ON until
    battery has been in use approximately two years or longer.
    Your electronic lock automatically performs a low battery test
    during each lock use.
    If a �low battery� condition is detected the Yellow LED will
    come ON and remain ON during each subsequent lock
    operation. (The lock will continue to function in a Low Battery
    state, until battery failure.) The Yellow LED will turn OFF only
    after three consecutive Good Battery readings or after the low
    batteries are replaced. (Note: If the new batteries are installed
    in less than 60 seconds the Yellow LED may come ON and stay
    ON during the first lock operation before it returns to OFF.)
    NOTE: It is recommended you replace the batteries after two
    years, or when the yellow LED remains on.
    Jan 09, 2011 | Safe International Electronic Digital Safe...
    The batteries of my powersafe TR 36 are dead and I don't have any key. What can I do to open the safe? Urgent! Thank you in advance!
    I know this post is months old, maybe you didn't open your safe yet or maybe someone else could use the advice.
    The batteries are no inside the safe because of this reason, that you should be able to change them if they run dry.
    Under the key panel is a long plastic panel. You can slide it to the right and underneath you find the battery compartment.
    4 x AA batteries
    Dec 30, 2010 | Safe International Digital Electronic Safe...
    Batteries are dead and I've lost the keys. Its an old electronic digital safe and I have the key number that goes with it. Know where I can get replacement keys or if its cheap enough to have...
    Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
    Please provide a rating for my help++++Thanks for using FIXYA
    Jun 15, 2010 | Safe International Digital Electronic Safe...
    How to unlock a cathedral electronic safe ea25
    After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
    inside of the door near the hinge.
    2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
    3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
    If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
    If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
    BATTERY REPLACEMENT
    This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
    To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
    YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
    TROUBLE KEY
    A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
    If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
    Nov 01, 2009 | Home Security
    Unable to open digital safe
    I have a similar problem as I have acquired (last night) a similar Woolies safe, locked, batteries dead & keys do not work. I am told you may be able to reset the code if you can depress the red button on the back of the door from the back of the safe through one of the bolt holes, easier said than done! Needs a stiff piece of wire or thin steel... good luck I will try this technique soon. These instructions were found by surfing the Net...
    Feb 12, 2009 | Ventamatic Gable Mount Power Attic...
    I locked my key in the safe and I CAN'T REMEMBER THE CODE THAT THE MANUFACTURER GAVE YOU WHEN YOU FIRST PURCHASE IT. psf80 PRO-SAFE ELECTRONIC DIGITAL SAFE
    Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
    Aug 18, 2008 | Office Equipment & Supplies
    Sentry Fireproof Safe Logo
    240 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Joseph Vernice
    Joseph Vernice
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
