Question about Polaroid TTM-2401 TV
Anntena terminal the terminal where i connect the cable is broken
  • 934 Answers
That's called the "F" connector and it attaches to the inside of the tuner, which is solder mounted to the main board. Main board has to be removed, tuner extracted from the main board and if the pc board inside the tuner is not damaged a new "F" connector can be soldered in place... At our shop we charge $60.00 for the repair and $2.50 for the part. I'm sure you'll find that's about average.
Bill
Posted on Dec 11, 2007
My mitsubishi tv has a phone jack looking plug then a anntena plug part , how do i hook up a dvd player to it
it could be an HDMI port for connecting HDMI cable. If your DVD player has HDMI output then you can connect it.
or it could be a usb port for playing videos from usb devices like pen drives and portable hard disks
i dont think tv has a phone jack
Feb 28, 2016 | Mitsubishi Televison & Video
On 2006 Suzuki aerio I put new battery in and lost all powers , have I blown a fuze?
Recheck both terminal connections...be sure black cable (ground) to black terminal on battery, red cable (positive) to red positive terminal on battery. If connections are clean and tight, you should be able to generate the motor/starter turning over, and all lights work...If you still do not have any power, the posts (dirty) or new battery is defective...(a broken terminal inside?
Sep 30, 2013 | Cars & Trucks
Cobra XL 29 Anntena Warning Light
If you have a SWR meter.put meter in line with coax. Dubble check coax and make sure its not pinched,cut. Antenna mount is tight and clean. No electrolysis build up At connection. Warning light is coming on for a reason. something is wrong in between radio and connection at the antenna.
Nov 23, 2012 | Cobra Radio Communications
I can't seem to get the analog channels when I do a search on my RCA lcd 37 inch? Can someone help
YOU HAVE TO CONNECT THE ANNTENA TO THE CABLE PART OF THE TV AND GO TO MENU AND SCAN SEARCH CHANNELS IT HAS TO SCAN THE CABLE SIGNAL FOR DIGITAL AND ANALOG SIGNAL IT MAY TAKE A FEW MINS YOU WILL HAVE TO DO THIS TO GET ALL THE CHANNELS
Jan 26, 2011 | RCA L37WD12 37 in. LCD HDTV
Change battery on 2005 nissan frontier wont start
Hi, If the problem is associated to you replacing the battery, then it could be a few different things. 1) Is the replacment battery fully charged? If not, charge and retry. 2) Are the positive and negative battery cables connected correctly to the battery? With this you have to be sure that you have a good connection to each battery terminal. Try removing the cables and taking a wire brush to the terminals. Once clean, reconnect them and try to start again. 3) Is the positive cable broken? If broken replace the cable. 4) Is the negative battery cable broken or properly connected to the car? If broken, replace the cable. Good Luck!
Jan 11, 2011 | Nissan Frontier Cars & Trucks
My 2000 Buick LeSaber turns but doesn't start, and the battery is completely dead. It seems it might be a short or a broken fuse. The way the Buick made this car the battery is in the back seat and the...
It could be a broken fuseable link in the battery cable,you can replace the battery cable the fuseable link is usually on the positive cable.It could be just a bad connection at the terminals in the front try cleaning both of them first with like a wire brush or 100-150 grit sand paper on the terminals metal surfaces.
Apr 15, 2010 | 2000 Buick LeSabre
Need help with digital converter box hookup
I located my owners manual and was able to resolve the issue
May 23, 2008 | Televison & Video
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Sanyo DS25390 Cable Terminal Ripped off
I personaly would replace the entire unit, the capacitor is a Ceramic "DC Blocking/Couplng" capacitor, possibly a 0.001uF cap... I should think if ya take it to any component supplier/radio repair shop or the like they would be able to give ya a replacement?
Jul 30, 2007 | Sanyo DS25390 TV
Polaroid TTM-2401 TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
