Question about Cameras
HOW TO SET TIMIMG ON pANASONIC Timer TB178K - Cameras
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Tb178k Panasonic timer
Copy following links for TB178 timer:
http://waterheatertimer.org/How-to-wire-TB118-TB178-timer.html
http://waterheatertimer.org/How-to-set-timers.html
The override button is temporary and regular schedule resumes at next tripper. So basically the override can be in any position.
Add a comment and describe timer in detail so identification can be made.
Jul 20, 2013 | Intermatic Hardware & Accessories
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
Relay switch between the timimg circuit and the spin cycle
Could be,the Timer ,going Bad.,replace The Timer .,found behind right backside of THE WASHER.
Jan 11, 2013 | Frigidaire FWSB5700DS Top Load Washer
On my panasonic viera tv i cannot set the sleep timer. the date/time are set properly but when i push 'menu' and then select 'timer' i am not able to select any of the options listed. please help!
If it is grayed out as an option on your menu, go down to Setup, then select Advanced Setup, and make sure "Auto Power On" is set to "off". This should then make the sleep timer function available to use.
Feb 22, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Cannot find out how to set timer for 3 hours for wholemeal rapid bake on machine number panasonic bread making machine sd-255/sd-254
You can't set a timer when you also set rapid bake - the two are not compatible.
If you set it to 'Bake' without the 'Rapid' setting, THEN you can set the timer.
Oct 29, 2008 | Black & Decker B2000 Bread Maker
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Cameras Logo
1,374 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
