Creating MESH on AP5131
Im facing problem in creating a mesh on Symbol AP5131. Actually i wanted to have communication on MC50 through AP
Pls help me in sorting this.
I need the default ip address,username and password.
Posted on Mar 31, 2009
  • 54 Answers
You must setup ap as repeater see manual
Posted on Dec 11, 2007
SOURCE:
I want to retrieve my old mtn sim i just bought a new sim
Transfer data between your cell phone and computer with Live-Mesh and then transfer to the new SIM. Click her for Live-Mesh.
Ben
Oct 07, 2011 | Cell Phones
How to configure symbol 5131 through hypertrm
Hi
You can set up the AP 5131 through Hyperterminal by accessing it through COM1 to start,
19200 bits per second
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
Apr 22, 2010 | Symbol AP-5131
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
Sep 15, 2009 | Symbol AP-5131
Yamaha PSR-GX76 musical keyboard problems
Does it have onboard speakers?
If so, try to tighten down (fix firmly in place) the wire mesh that protects the speakers, if it's loose, it will vibrate and cause distortion in the sound.
I once had to repair a portasound which sounded really crappy when a group of keys was struck at high volume, and it would only calm down when i fixed the speaker mesh so that it didn't vibrate with loud sounds.
You may want to put some rubber or similar into the groove where the mesh edge fits in to prevent it from vibrating (i solved mine just by tightening up the mesh strips where they protrude into the housing).
If this doesn't help, then it's something else (possibly a bad or dirty connector contact or a bad solder contact).
regards
3rq8 (Triarcuate)
Jul 30, 2009 | Music
My symbol 4131 and pdt4686 won't associate. Please help.
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual:
http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
Jul 01, 2009 | Symbol Spectrum24 4131 Access Point...
ILLUSTRATOR MESH TOOL
Hi! You can use the mesh on any shape. First you make your circle with the shape tool and then get your mesh tool and click inside the shape. Each time you click it will add more lines to the mesh. Then you can use your direct select tool (the white arrow) to select each point and change the color. The point's color is bounded by the lines around it so you can also use the direct select tool to move points around or change the shape of lines by moving the "handles" you see when you click on a point. Once you start playing with mesh it can be very fun!
Feb 19, 2009 | Adobe Illustrator CS2 for PC
EnGenius Mesh AP
you will get a software which hacks the ip address search in google pls rate
Jan 20, 2009 | EnGenius EUB-362 (EUB362 EXT) Wireless...
MC50 scanning engine
http://www.symbol.com/ is who you should goto since it is a enterprise device. Not many people have the dev kits for these devices.
I only have experience with mc9000. I know when it refuses scan (or activate) is has to do with the software being used to communicate with the scanner itself. Re flashing the device usually fixes it.
Aug 22, 2008 | Symbol MC50 Portable Terminal
Connecting on 802.1x wireless network
www.socketcom.com
WIRELESS NETWORKING DEVICE 20PK SDIO BT CARD FOR MC50- [Manufacturer/Brand] SOCKET COMMUNICATIONS [Model/Part Number/SKU] BL4805-652, BL4805652
Apr 09, 2008 | Symbol MC50 Pocket PC
Computers & Internet Logo
936 people viewed this question
Alun Cox
