Question about HP Computers & Internet
Export controler has stopped working in vista
When I open quicktime I get the message ''Export controller has stopped working'' eventually the program opens after a delay. I have reinstalled QT but that didn't work! I have googled the error but came up with nothing!
Hollyecho
  • 313 Answers
SOURCE: ADmin rights on Vista Home Basic
For vista
Open the control panel and select System and Maintenance.
Scroll to the bottom of the page and select Administrative Tools.
In the new window open Computer Management.
From there open System Tools.
Now open Local Users and Groups.
And finally open Users.
Right click on the account named Administrator and select Properties.
There is a series of tick boxes in the lower half of the properties window deselect the one saying Account Is Disabled.
Apply the changes and Log Off, there should now be 2 accounts in your log in screen, select administrator.
when you go to delete your old account it'll ask you if you want to save the documents and settings from it. say yes and copy the files from the folder into your new admin account.
Posted on Jul 17, 2008
SOURCE: Camera not working
This works better and is within the Kaspersky help.
Fine-tuning rule settings Application Filtering rule applies to a great number of system resources and actions to be performed with them.
In order to fine-tune the application rules for actions to be performed with system resources:
  1. Open main application window
  2. In the left part of the window select System Security.
  3. Press the Application access rights link in the Application Filtering section.
  4. In the window that will open select tab Applications.
  5. Select the application in the Program column.
  6. Press the Edit link in the bottom part of the tab.
  7. In the window that will open select tab Rules.
  8. Select a resource category for which a detailed access right configuration is required using a drop-down list in the top part of the tab.
  9. Open the shortcut menu for the column containing actions to be performed with protected resources.
  10. Select the required menu access rights.
  11. Save changes.
Posted on Sep 05, 2008
  • 11 Answers
SOURCE: Power Saver does not open, Toshiba Satellite 1415-S-173
While on the Desktop RIGHT CLICK the mouse and LEFT CLICK on PROPERTIES. LEFT CLICK on the SCREEN SAVER tab. Then LEFT CLICK on the POWER BUTTON. From here you can change your power options.
Posted on Mar 05, 2009
rahmanus
  • 52 Answers
SOURCE: I can't open my add/remove programs
there too much reason we had any problem with the windows menu etc.. maybe because missi any registery, our computer are infected with any malware, trouble with registery key, missing any registery or component etc..
there are some tips 4 u
a) To fix the problem with missing any registery key
open the command prompt by click on start menu-->run or start menu-->accesoris-->command prompt.. after did these following
  1. type CMD.EXE prompt.
  2. Type regsvr32 mshtml.dll and press Enter and OK.
  3. Type regsvr32 shdocvw.dll -i and press Enter and OK.
  4. Type regsvr32 shell32.dll -i and press Enter and OK
i hope this one will work :)
if u still have the problem :
b) try cc cleaner tool or:
c) if u have another account try open it with each account if not work try with safe mode or:
d) update your anti virus and scan ur computer then
e) put your windows cd and run the fix menu appear or:
f) restore ur computer setting start-->control panel-->system-->system restore tab.or:
g) reinstall ur windows..
i hope u luck
Posted on Oct 02, 2009
SOURCE: export controller has stopped working (vista 32 bit)
Deinstall it. If you got this with iTunes 9 deinstall that as well and go back to the previous versions which can be found on the Apple website under support. I got rid of both of them and reinstalled iTunes 8.2.1 with quicktime and all of the various programs that were giving me "stopped working" messages all started functioning properly again.
Posted on Oct 05, 2009
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
My itunes just stopped working one day and now i can not reinstall it on my computer
Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this article.
Expand All Sections | Collapse All Sections
In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
  1. Quit iTunes.
  2. From the Start menu, choose Control Panel.
  3. In Control Panel, open Add or Remove Programs.
  4. Select iTunes from the list of currently installed programs, then click Remove.
  5. When asked if you would like to remove iTunes, select Yes.
  6. After the uninstallation is complete, do not restart your computer if you are prompted to.
  7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
  8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
  1. Quit QuickTime Player.
  4. Select QuickTime from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove QuickTime, click Yes.
  7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
  1. Quit Apple Software Update.
  4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove Apple Software Update, click Yes.
  7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, open Add or Remove Programs.
  3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
  5. After the uninstallation is complete, do not restart your computer if you are prompted to.
Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
Removing Bonjour
  2. In Control Panel click "Add or Remove Programs."
  3. Select Bonjour from the list of currently installed programs then click Uninstall.
  4. When asked if you would like to remove Bonjour click Yes.
  5. After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
  3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
  1. Restart your computer.
  2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
  3. Open the Program Files folder.
  4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
  5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  8. Open the Common Files folder.
  9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
  11. Open the Windows folder.
  12. Open the System32 folder.
  13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  15. Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. Press and hold Control-Alt-Delete. Select Start Task Manager.
  3. Click the Processes tab.
  4. Locate "iPodService.exe" in the list.
  5. Click "iPodService.exe" and choose End Process.
  6. Quit the Task Manager.
Aug 04, 2010 | Apple iTunes
Windors live quicktime control host has stopped working
You need to Uninstall & Reinstall the quicktime program.
Mar 25, 2010 | Microsoft Windows? Vista Home Premium...
After installing QuickTime all links to other quit working
You can use the uninstalled that comes with quicktime or you can use add/remove program in the control panel.
Dec 16, 2009 | Apple QuickTime
Quick time
Have you tried to do a complete uninstall. You will also have to manually go to C:/windows/program files/QuickTime and delete that folder Manually after the uninstall as well. Then do a reinstall this should resolve the issue you are having.
Oct 03, 2009 | Computers & Internet
Quick Time 7 not working! Export Controller not working!
download K-lite Mega codec player............play all stuff enjoy......
Oct 01, 2009 | Apple QuickTime
Both my export controller and my windows installer dont work
hi,
first get in to start - run - services.msc. check wther windows installer in started or stoped. - if it is already running restart the service.
2. uninstall the existing itunes by going into add or remove programs.
3. reinstall the latest one.
Sep 24, 2009 | Computers & Internet
Export controller has stopped working (vista 32 bit)
Sep 17, 2009 | Apple Computers & Internet
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Computers & Internet Logo
1,168 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
