Question about Yamaha Electric Guitar
My guitar string is broken but it's on a electric guitar. please help me because my lesson is in october
    Problem Solver:
  • 10 Answers
Use a guitar guide like raeguitars
It's great, help me with every little thing that cropped up over the years.
Posted on Nov 30, 2009
  • 454 Answers
Always keep an extra set of strings. Trust me, if you play daily, they will break often. Your guitar instructor will show you how to change strings and tune it.
Posted on Nov 05, 2009
    Problem Solver:
  • 10 Answers
Does that guitar still has warranty? where did you bought it? try to go to music repair shop and consult it. they will help you bigtime. promise. i hope i helped you even a bit. thanx
Posted on Sep 13, 2009
  • don victor famas - III
    don victor famas - III Sep 13, 2009
    you still have time because your lesson is way too far.
  • Painter33 Feb 02, 2015
    Trying to get a warranty repair or replacement based on a broken string? Replacing strings is not complicated. As above, your instructor will show you and there are many online resources that explain how to do it. Please don't think this is a warranty issue because it isn't.
How change strings gibson guitar?
One of the best was to keeping your guitar in tune, is to also string it correctly and use new strings . Make sure the first winding of a new string around the tuner post goes over the exposed tip of the new string. The rest of the windings go under the exposed tip of the string. This will keep the string clamped firmly in place. Use 4-5 turns around the post for unwound strings, 2-3 for wound strings, in a downward spiral towards the bottom of the post as shown in the photo.-Tom, 30yr player.
Apr 15, 2016 | Gibson Les Paul Studio Electric Guitar
My neck of the guitar is broken. Please suggest a poosible way to repair this. Guitar is Samick Avion AV 3.
This is very serious as a broken neck means a lot to the guitar. It depends on the section broken and if the fret is also damaged.
Since the neck needs to be quite strong as the strings are tightened and must not in any way bend or be soft-- as the TUNING WILL KEEP ON CHANGING- the neck must be wedged back and then maybe the use of a counter steel reinforcement might be needed.
It is best to get this done professionally , if you intend to get this guitar to retain the quality.
Sep 13, 2011 | Samick Greg Bennett Avion AV-3 (Black)...
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I don't know how to change the strings on my shector 006 deluxe, any help please? ive had the guitar a few months now and think it is due a change in strings, however i feel unsure about uncsreweing parts...
There are instructions on YouTube.com regarding changing strings on guitars. The video illustrations are much better than trying to write in words the proceedure.
Apr 23, 2010 | Schecter 006 Deluxe Electric Guitar...
One string broken, how to refit it?
Sorry Dude
If you can not replace a broken string, then you need a few lessons from a friend.Find a pal to jam with.
It sounds like you broke your E string. Take it down to the local music shop. Buy a new string and ask the guy to put it on for you. Offer them a tip, its worth it.I could tell you. But you need the string so ask for assistance and see it in 3D. Keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
Which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Feb 26, 2009 | Washburn X10 Electric Guitar
Dean razorback DB problem
If the neck of the guitar is a bolt on neck (their will be a plate holding the neck onto the body of the guitar with several screws) then this is typical. Some strings will give off small vibrations. Nothing is wrong with the guitar, usually with a string change or with time the tone will fade as the strings change to the shape.
Hope this helps,
-Aaron C.
Jan 25, 2009 | Dean Razorback Db Electric Guitar
Yamaha Electric Guitar Logo
258 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
