Tried to photocopy seemed jammed after whirring noise and a clunk. does not appear to be any paper jammed inside
Why is there a paper jam from cartridge?
There could be a hard-to-find shred of paper stuck inside. You may have to use a strong light and even do partial disassembly to locate the source of the jam.
Jul 27, 2015 | HP LaserJet 2727NFS All-In-One Printer
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
In 2 wheel drive there is a whirring sound from the front end followed by a loud clunk where it feels as though you have run over a large rock or chunk of ice. Does not seem to occur in 4wd
if the whirring you describe sounds like an airplane and increases with speed that would be a wheelbearing and it may be loose to cause the clunk noise. when it is put in 4 wheel drive that can load the bearing up and noise goes away.
Feb 09, 2010 | 2001 Kia Sportage
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Won't print or copy due to ''paper jam''
the gears in the printer which pulls the paper r either blocked some where or r worn out.and needs replacement.
Nov 14, 2008 | Lexmark X5250 All-In-One InkJet Printer
Paper jam and possible failure to pull A4 paper ?
1- you must remove the jam paper first
2- set the tray to LETTER or LEGAL not A4
A4 is european size not used in the U.S
Make sure the paper adjuster in the tray is touching the end of the paper size, also there should be some markings in the tray.
The noise is coming from the jammed paper, it is trying to feed itself but is stuck.
Dec 24, 2007 | Office Equipment & Supplies
20 people viewed this question
k24674
jasbo
jasbo
