Question about Dynamo Pool & Spa
How to repair an old lawn mower dynamo - no spark
How to repair an old lawn mower's dynamo - spark weak.
Its a rather old ATCO 2-stroke cylinder (aka reel) lawn mower. Has worked well for years and years, but now spark is too weak to work. I tried cleaning the plug, which worked a week ago, but I noticed the spark was really weak. Started then stalled after a few minutes today, wont restart. Time to look at the dynamo?
Is it easy to repair/improve the spark fairly easily?  - barnsfromOz
    Top Expert:
  • Dynamo Master
  • 7,436 Answers
Check key in flywheel if you hit something cuts key replace
Posted on Feb 18, 2018
  • 211 Answers
SOURCE: My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
  • 17 Answers
SOURCE: lawn mower does not start up
Lots of thing can stop a victa working!!!!!!!!!. Ok your plug is wet. Turn the fuel off. R&R tank renew fuel(no more than a month old it goes stale)Check for spark, be very careful it could catch a light.
Get the new plug open the gap to about the hex of the plug to the head, away from the plug hole ,the fuel will come out.
If it jumps gap when pulled it has enough spark to fire under load.If lots of fuel comes out its flooded.if so leave plug out remove a/f ,leave tap off, put throttle to full and pull till most fuel is gone.Refit plug and try. let me know how that goes. do this in well vented area. Fumes can build up in shed.
Posted on Jan 08, 2009
  • 246 Answers
SOURCE: can't start toro mower. cleaned spark plug , new
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
Hope this Helps.
Good Luck
Posted on May 10, 2009
  • 133 Answers
SOURCE: engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
Posted on Aug 22, 2009
  • 128 Answers
SOURCE: Hayward super pump II low pressure 10 psi suction and return low
You have a clogged impeller
Posted on Aug 23, 2009
Testimonial: "thanks for the response. That is exactly what it was. Got frustrated and just started taking things apart, but you are right on the money! tks again."
Hello my name is paul and i am looking for a work shop manual for my atco 12/36 rideon lawntactor model 830 would you know where i can get one from please
Workshop manuals are usually only found at dealers. Try some of these links though.
  • ATCO - Official Site ... ATCO is a diversified global corporation delivering service excellence and innovative business solutions in Structures & Logistics (workforce housing, ...
  • Atco Product Support ' My atco balmoral 17 rear roller jams when trying t. ... Service manual for atco balmoral 14s. ... manual Atco Commodore B17.
  • Atco Operating Manuals ' The Old Lawnmower Club Atco Operating Manuals. View (active tab) What links here; ... Title ; atco1246.pdf: Atco 1246 : Atco 141720.pdf: Atco 141720 : Atco 172055.pdf: Atco 172055 ...
  • Atco Lawnmowers - The Finest Cut of All Atco Lawnmowers Since our first lawnmower in the 1920s Atco has had an enviable reputation for the outstanding quality of our cylinder mowers. Save up to £100, from £899.
  • Operating Manuals ' The Old Lawnmower Club The following operating manuals are available for free download from the site. ... Manual ; Atco 1246: atco1246.pdf: Atco 1755 and 2055: Atco 172055.pdf:
  • Old Lawnmowers and other Vintage Machinery Old Lawnmowers and other Vintage Machinery. ... We have a range of Operation Manuals, ... Allen Motor Scythe Model 'T' , Early 1950s ; Villiers Atco 12" Hand Mower ...
  • Lawn Mower Manuals - How to Access Old Mower Manuals > How-To Library Shop by Brand [+] All Brands: Shop by ... However, finding a manual for a specific model can lead you on an Indiana Jones treasure hunt. ... Lawn Mower Manuals ...
  • Free Atco Lawn Mower User Manuals ' Find the user manual you need for your lawn and garden product and more at ManualsOnline ... Atco Lawn Mower Manuals. Showing Products 1 ...
    Sep 14, 2016 | Garden
    What oil to use for a yardworks gas mower 060-1648, 060-1649, 060-1658
    Hi , There's two different types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) Ask at the local lawn mower repair store for the oil type and the 2 stroke grade, it's just two stroke oil you add to the gas (2 stroke mowers ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then NO you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
    May 10, 2016 | Garden
    Why wont mower run after being run with too much oil in it
    single cylinder four stroke engines and to much oil is a recipe for breaking things internally. Piston comes down tries to compress uncompressible oil and excessive pressure breaks one or more items. If it did run and just stopped without any dramatic bang or clattering of broken parts you may just need to completly drain it, refill to the correct level, replace the spark plug and check the air filter (may have puked up oil and clogged the filter....even laying the mower on the airfilter side will do this.
    if its a two stroke mower and you put in to much 2 stroke oil. Drain the fuel, remove the spark plug, cover the lead (so you dont ignite fuel with a stray spark), pull the handle a few times to clear out the cylinder. Clean and replace plug, put in correct fuel oil mix, check airfilter is clear and it should live again.
    Aug 14, 2014 | Garden
    Atco manual
    In the UK the Merry Tiller was produced by the Wolseley company until the 1980s when a change of company policy led to the manufacturing side of the business being sold off to Atco. Over the years the design had changed, making it more expensive to produce. This, coupled with changes of Atco's ownership and increased competition, led to the end of production in the UK.
    Jul 09, 2014 | Garden
    White smoke coming from 4 stroke lawn mower
    It is most likely oil. Probably passing past the rings on the piston. I use 2 stroke oil in all my mowers / small motors whether they are 2 stroke or 4 stroke (based on advice from a small motor repairer) since the 2 stroke oil helps lubricate the bore and even though there is some minimal smoke usually on start-up. Depending on how bad the smoke is you can try a heavier grade oil and I would recommend using a 25:1 2 stroke mix if you want to extend the life of your small motors.
    Jan 31, 2013 | Garden
    How to fix a 3.5 lawn mower?
    You can fix these yourself, all you have to do is to follow the instructions below,
    1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
    2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
    3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
    4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
    5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
    6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
    I hope this will help to solve the problem.....
    May 31, 2011 | Craftsman Garden
    How to repair an old lawn mower dynamo - weak spark
    Replace the plug with new, non champion if possible, That is what I would do first.
    Aug 21, 2017 | Dynamo Pool & Spa
    I need a user manual for a atco B14E lawnmowerand I need to know if it is a 98cc or a 114cc as I need a new head gasket.
    If the head is off, physically measure the bore & stroke and work out the displacement. Quicker and easier than tryng to track down a manual, and you wll need the date of manufacture to ensure you het the correct verson anyway.
    Sep 05, 2009 | Garden
    Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
    Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
    Aug 30, 2009 | Garden
    No spark
    After seeing what you and other ASK type web sites charged to answer my question, i called the dealer he answered the question for me. i ordered the part online and repaired it myself.
    My advise before you pay anyone to answer your question try calling a local repair center, i found they were willing to answer my questions without a CHARGE
    May 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
    Pool & Spa Logo
    85 people viewed this question
    Top Dynamo Pool & Spa Experts
    Jay Finke
    Jay Finke
    Gil Shultz
    Bosse Photos
    Are you a Dynamo Pool and Spa Expert? Answer questions, earn points and help others
