Question about Garmin GPS
Garmin nuvi 850
Pre-boot mode
SOURCE: garmin nuvi 660 personal travel asistant
Do you know how can I do hard reset in Garmin 660
pelek82@o2.pl
Posted on Mar 12, 2008
  • 3422 Answers
SOURCE: Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Posted on Sep 30, 2008
  • 20 Answers
SOURCE: Garmin nuvi 610
https://buy.garmin.com/shop/buymaps.do
Garmin offer new maps, the majority in different formats such as online downloads, pre-loaded SD cards, or on DVD.
However, these are pretty costly for all they are worth. For the same price as a map, you could easily buy a brand new device with full EU maps.
Posted on Dec 11, 2009
SOURCE: my garmin nuvi 5000 is
Mine was doing basically the same thing. Ended up being the power cord. Put a new cord in place and everything was normal.
Posted on Aug 05, 2010
sharcnet
  • 2130 Answers
SOURCE: Garmin nuvi 660 goes into
There is a transient diode across the switch. Most likely it's shorted, casuing the symptom as if you were holding down the power switch and never letting go. I've seen and repaired this before.
- Jim
SHARCNET-USA
Posted on Sep 30, 2010
Garmin nuvi 660 goes into pre-boot mode, then loading, then loading software, then back to pre-boot mode and keeps looping through the 3 steps, and it won't shut down
- Jim
SHARCNET-USA
Sep 11, 2010 | Garmin Nuvi 660 GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
No voice directions
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps.
Jan 03, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Stuck with pre boot mode on screen
"Will not turn off, stuck on with display saying 'pre boot mode'. Does nothing but this - please help!"
This indicates that the on/off switch is shorted out. You can duplicate this problem by taking a working Nuvi and keep holding down the on/off button when turning it on. It will stay in this mode until you let off on the power on/off button.
- Jim
Jun 07, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
