Question about Konica Minolta bizhub 350 All-In-One Laser Printer
After using foxfire to open page scope it will not let me use ie to open page scope anymore on my konica 350
How do i replace the image transfer roller unit on bizhub 350?
Periodical replacement for IMAGE TRANSFER UNIT is 150,000-print 1. Open the Right Door. 2. Pull down the blue knobs [1&2 ] forward and remove the Transfer Roller [3].
User Copy Operation Handbook page 5-9
Jan 31, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
FoxFire not working properly
then it may because of your addons and themes
Apr 11, 2010 | Mozilla Firefox
HTTP 400 BAD REQUEST
First, try updating windows. (Read everything below).
There is an error in windows .Net framework 1.1. Microsoft has a fix for this. You can read about it & manually repair this error at MS site. Click on the link below;
http://support.microsoft.com/kb/826437
What you want to do when updating windows!
Do not use Express. You want to install all .Net framework updates (one at a time). Re-start your system when windows tell you too. There are updates up to .Net framework 3.5 with (SP3) & this will take some time.
Cheers!
Run into a problem, post it here.
Mike
May 03, 2009 | Computers & Internet
Installed an HP j4680 all in one printer. Can print e-mails when I sign on to aol via foxfire, but can NOT print aol e-mails via IE
are u using internet explorer 8 if yes then this is a genuin problem with it actually ie 8 doesnot support the hp smart web printing feature and there is no update by hp till now for ie8 so its better u sitch to ie 7 or continue using firefox for printing
Apr 30, 2009 | Computers & Internet
Issues with Windows Vista
i think u r system affect by spyware so try this http://www.avg.com/
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
Mar 22, 2009 | Computers & Internet
Having trouble with both internet explorer and Mozilla Foxfire browsers not working anymore. Any suggestions on how to fix this probem? Both browsers used to work until I tryed to download the AVast...
Well the network adapters don't have anything to do with IE and FireFox. Those programs got corrupted for some reason. Best thing to do is go to microsoft website and download a fresh IE and then find firefox website and reload...
Good luck..pls rate.
Feb 28, 2009 | HP Computers & Internet
Cannot access PageScope Web Connection in client PC
first try to ping this address, to see that this pc finds printer. you have to check network settings for that pc
Apr 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
