Question about Intel D845GVSR Motherboard
Dvd drive problem
I cant see dvd drive in my computers
os - is xp professional
  • 448 Answers
If the CD/DVD drive is not visible in the "My Computer" window but it's listed in the Device Manager under the "CD/DVD Drives" category then editing the Registry would resolve the issue.
Follow the steps given below to edit the Registry settings for the "DVD Drive":
(i) Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box.
(ii) Then, please type "regedit" in the Run dialog box and click OK to open the "Registry Editor".
(iii) In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
(iv) In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
(v) In the System folder, double-click the CurrentControlSet folder.
(vi) In the CurrentControlSet folder, double-click the Control folder.
(vii) In the Control folder, double-click the Class folder.
(viii) In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
(ix) In the right pane, right click to select the UpperFilters registry value then click Delete.
(x) If LowerFilters value is there then delete that also by following the above procedure.
Note: Do not delete the UpperFiltersBak or LowerFiltersBak registry values.
(xi) Close the Registry Editor and restart the Computer for the settings to take effect.
Posted on Sep 13, 2009
    President:
  • 1,188 Answers
Can you see your DVD drive listed in the deceive manager (right-click My Computer-->Properties-->Hardware-->Device Manager)?
If not then shut down your pc and remove the power cable. Check if your dvd drive is connected to the power and SCSI cables (the flat thin cable).
Check if you have correct jumper settings: if the drive is on single SCSI cable then the jumper should be set to Master. If two drives are used then on one drive it should be set to Master and the other Slave.
IF your dvd drive is listed in the Device Manager then right-click it and un-install it. Restart your pc and see if it appears.
If it still is not there then there is probably a virus infection in your OS or some files are corrupt. Reinstall XP and it will surely solve the problem.
  • 497 Answers
Check this Link and delete the UpperFilters and LowerFilters registry values to resolve the issue.
http://support.microsoft.com/kb/314060
Also restart the computer after deleting the registry values.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OS is Windows XP Professional, my cd drive cannot read the data stored on a DVD disk. My driver is HL-DT-ST CDRW/DVD GCC4482. Thank you
Windows XP is no longer supported, you should up-grade to Win 7 or buy a new computer. As for the DVD that it can't read, try it on a friend's computer and see if it works. If it does, your DVD/CD drive is defective or there is a software driver issue which means you can't receive support from Micorsoft.
Jun 16, 2013 | Dell Dimension 3100 PC Desktop
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
if you need more help with this post a reply
hope it helps
May 25, 2012 | Microsoft Windows XP Professional SP2 for...
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mar 11, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have dvd ram drive , so can i get dvd rom on my windows Xp professional?
Yes, it should support it, as long as you have a dvd drive in your computer to read the discs.
DVD rom, is just a regular dvd, DVD ram is a software configuration in windows, see below for more info on DVD ram:
http://www.mytechguide.com/26/using-dvd-ram-disc-under-windows-xp/
Thanks
Mar 07, 2011 | Microsoft Windows XP Professional
Cant play DVD's on PC
1st thing to check is you have a DVD drive installed in your computer, if you look at the drive it self it should have DVD or CD embossed on the front of the drive, if you only see CD or similar you can't play DVD's, if it does have DVD or similar you may need to install DVD software, have a look on filehippo.com for some software.
Feb 15, 2011 | Microsoft Windows XP Professional
Cant find cd/dvd drive in my computer
Go to the manufacturers website and download the firmware update. This should allow windows to find the unit again
Apr 10, 2010 | Microsoft Windows XP Professional
How to install windows xp on preloaded vista
If you have Windows XP OS installation CD, just put it in and boot your computer.
Leave the system till it comes to a blue screen. Choose to install a new OS and follow teh on-screen instructions.
Choose to format the C drive if you wish to delete Vista and the data in you C drive. Proceed with the instructions and you will be able to install the OS.
Hope this helps!
Mar 29, 2009 | Microsoft Windows XP Professional With...
Install Fedora
If you are using 2 hard drives then install Fedora to the 2nd drive. When you boot up it will ask you which os you wish to boot into. Hope this helps.
Dec 22, 2008 | Microsoft Windows XP Professional
DVDRRW recognizes CDs, not DVDs.
What PC ,
HP Pavilion Media Center TV m8100n Desktop PC
what OS, we cant guess, OS, ever. say it. please.
then we can talk. it came new with XP/VISTA/W7
which one is yours? (then and now, did you upgrade to w10 for free? we cant guess that either,)
"regardless of type (DVD )" does that mean , using program manager
explorer, (my PC, my computer,app) cant see files on a real
store bought DVD? or cant read any windows disks, real install DVD? from HP or MS?
or cant read DVD-r , Only, ? be more clear on media, even give a real example .
like my computer app runs and sees it but media player don't.
ill guess XP and real DVDs can not be seen by ANY means.
if running XP , why? XP is not only a Virus magnet ask (UK hospitals that fun....)but also , has no support or is buggy on many DVD drives made. and also many USB ports and devices can be dead on XP, XP sux really... and vista close 2nd
If not on W7, upgrade it now, and win. really.
if not already.
never post lacking OS or the post will go NOWHERE fast.
there are patches for XP, for 16 long years, endless.
HP has none
MS has none, (ok 1)
you just dig them up from the toxic internet of viruses..
the toxic soup.
got SP3 from XP that is mandatory in all cases, and the reg patch for DVDs. yes, there is one.
as is the one and only, 3 month old MS patch to stop
the RANSOMEWare. attacks.
what OS what OS what OS?
May 22, 2017 | HP 5188-7537 DVD Writable CD-RW...
Intel D845GVSR Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
