Question about Dacor Preference RSE30 Electric Kitchen Range
BEZEL CRACKING ON DACOR RSD30S - Dacor Preference RSE30 Electric Kitchen Range
I have this problem and just called a parts store to find that a new bezel is $414.79! The screws were apparently loosening up slowly and by the time they were scratching the trim piece on the top of oven door (and I noticed it) the damage had been done. Has anyone been able to get Dacor to replace this part w/o charge? It isn't a case of misuse, but is a design flaw. Lindsey
Posted on Jan 14, 2010
I was wondering if you ever got a resolution to your problem with Dacor replacing the bezel due to design flaw. Thank you(not a solution but a question).
Posted on Oct 31, 2012
F1 error code on Dacor RSD30S. Code comes on for no apparent reason, range not in use. Hitting cancel no longer resets range, I have to pull fuses to stop beeping.
The F1 error code means that a button on the touchpad is stuck and sometimes it could be resolved by clearing the code by pushing the cancel button, having done that and it no longer clears that F1 code the touchpad would need to be replaced to keeping it from beeping nonstop.
The part number for that touchpad is 82063B it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kitchen Ranges
Dacor RSD30S F1 Error Code
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
My RSD30S Dacor Range is giving an F1 error code for a while now. What is the expected total cost of repair?
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 26, 2011 | Kitchen Ranges
Oven is flashing F0 how do I tell if it needs the bezel with touch keys or a ERC?
Hi dennis_r_mei,
Just replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Need to replace bezel for instrument cluster in 2003 discovery
The seal in the bezel is probably dried and cracked.The bezel and lenze are easy to romove. Just turn it until the teeth line up in the back and it should pop loose. -------- Remove the instrument panel top cover.Remove the screws and remove the cluster bezel. Check out.Thanks.Keep updated.
Oct 01, 2010 | Land Rover Discovery Cars & Trucks
Sparks and lightning like flashes appear when the microwave is on. It is a Dacor 24''
If something like a knife, spoon or fork is in the micro, this usually happens. It could also be that the interior of the micro may be damaged due to rust. Check for open metal, cracks or paint missing on the inside of the microwave.
Oct 17, 2009 | Dacor Microwave Ovens
Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
May 18, 2009 | Dacor ECS130 Epicure Electric Single Oven
RSD30 F1 Error Code
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection. why would he replace the spark module?if the door is not closing>>> are the burners not igniting?
Bezel Panel
76480b/r BEZEL (Almond/Black/Arctic)
Spark Module
86526 SPARK MODULE, 4 POINT,
Both door hinges
82883 HINGE, DOOR
* 82508 HINGE, DOOR (Stainless Front)
or to fix your F1 error
92028 RELAY PCB, 105 C
Aug 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Dacor Preference RSE30 Electric Kitchen Range Logo
678 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
