Question about Epson Stylus Photo R1800 InkJet Printer
Lines across the paper and uses a lot of ink fast. Where can I get it serviced?
  • Epson Master
  • 511 Answers
It might be caused by ink leakage. Did you refill ink tank? Check for rubber seal at bottom side of ink tank. It might be deteriorated. Use new ink tank. If it'sn't resolved, take to epson service center nearest to you.
Posted on Sep 13, 2009
Printing horizontal solid lines across paper - have done all diagnostic testing but still solid lines across paper.
Hi
Well it is possible that the nozzles are clogged. You did good in troubleshooting the issue, normally head cleaning cycle will resolve that, but if it fails and out of warranty. Best suggestion is to get a new one since head cleaning cycle from printer settings will consume a lot of ink and not a guarantee to work in printers behaving like what you are getting when printing.
Thanks for using Fixya!
Apr 02, 2010 | Epson Stylus photo C87 InkJet Printer
When I am printing photos, there are color lines horizontally across the photos?
Have you tried the "clean cartridges" button in the Printer Htoolbox? Also,does your color cartridge have ink? If the "clean cartridge" option doesn't work, take the cartridge out of the printer, put a small amount of hot water on the paper towel and push the paper towel up against the cartridge ink jets. This often opens up blocked ink jet ports. Dry the cartridge with a dry paper towel and put it back in and give it a try. You don't need a lot of water, just enough to get the ink flowing. Hopefully this will help. Good luck!
Mar 08, 2010 | HP Deskjet D4260 Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Lines across paper when photocopying on a canon #D-320
take it back to the store or call the canon customer service
Jan 06, 2009 | Canon imageCLASS D320 Digital Copier
Black lines on prints
Remove the cartridge.....
using a cotton bud clean the ink nozzle area on the cartridge for excess ink..take extra care not to damage the nozzles
... while at it take a piece of rag and try to clean the..service station area(this is where the cartridge goes to the side of the printer)for ink build ups....try to clean the rubbers that wipe the ink off the head as it runs across ..this is near the service station area clean well
it just requires cleaning..try to use little bit of cleaning solution that is available for that particular model..if not use bit of alcohol but do not use it on the cartridge itself ..make sure the alcohol is properly dried as not to damage the head
do reply if this helped
Nov 11, 2008 | Epson Stylus Photo 1280 InkJet Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Epson Stylus Photo R1800 InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
