Question about Kitchen Appliances - Others
Re-fitting triton t80si shower after bathroom refurb and just need to know do we need to seal the new plumbing pipework to the shower unit with jointing compound or pft tape or just compression and olive ? I will be using a flexi pipe to go from mains to the shower.
  • 76 Answers
Jointing compound. Wen we talk bout water work nothing is to safe.
Posted on Sep 13, 2009
Testimonial: "Thanks for superfast reply and confirmation of safety issues - cheers !"
I need a new shower unit that will fit my existing plumbing and electrics
most shower heads are the same size plumbing . pick out what you like and get it installed
Jan 05, 2016 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Buy a new shower to fit plumbing for triton bewitch
Most triton showers are compatible with each other take screws at top and bottom of cover out and see if left or right hand entry for plumbing
Sep 24, 2012 | Home
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
My triton shower pump has a leak from inside where the shaft is all the joints are ok where the pipes fit
The pump has a seal in it that needs to be replaced. You should be able to get the seeal from a local pump repair shop if you take them the old one to identify.
Aug 29, 2009 | Plumbing
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Kitchen Appliances - Others Logo
149 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
