Question about Dynex 32 in. LCD Flat-Panel HDTV
What is dynex 37'' screw size?
I have a dynex 37'' and what is the size of the screws to be attached into the stand
Are the screw size of dynex 32" and 37" similar? thx
  • 27 Answers
SOURCE: Lost Screws for stand for Insignia IS-LCDTV32 32
they are couse scews your best bet is go to lowes or home depot and get a few of each 1/4 inch screws to see which one fits they only cost about .03 each
please rate my answer it is much apreceated
Posted on Feb 13, 2009
onyeobike
  • 70 Answers
SOURCE: screw size needed
I strongly advise and recommend you get the details and if possible the screws from the shop you got it from.
This advise is enssential so as to get the best from the certified sales representative
Posted on May 25, 2009
gowtham-xxx
  • 5 Answers
SOURCE: what size are the screws that fit in the back of a
2 inch.
Posted on Jul 10, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
  • 3 Answers
SOURCE: Hepl removing DYNEX base
Remove the four small phillips screws facing the back of the TV/Base and the whole base will come off
Posted on Sep 21, 2009
What size screws attach the swivel base to the Dynex LCD-TV Model DX LDVD19 10-A? There are screw holes. Many thanks!!!
take it to a repair shop and have them check the hole size they may actually have screws just for that reason
Nov 05, 2017 | Dynex Televison & Video
What kind of screws to I need to attach the stand to the 19 dynex flat screen?
They are most likely metric, you can go to a hardware store like ace and get several common sizes and see what ones fit. WATCH out to make sure they are no too long
Jan 25, 2017 | Dynex Televison & Video
Olevia 532 base stand screw
hi, did you find your answer? I have the same problem. eointosullivan@gamil.com
Jun 27, 2012 | Syntax Olevia 532H 32 in. LCD HDTV
Missing screws for detachable stand for vizio e370 va
Try to contact (says your set is Vizio here) the company who made it...Also try to GOOGLE MODEL NUMBER OF SET WITH "MOUNTING BOLTS"
Mar 24, 2012 | Vizio E370VA 37 1080p 60Hz LCD HDTV
What size screws do you need to mount a 32" vizio lcd tv
according to manual the screw type is M6 , 1.00mm pitch and length is dependent on thickness of stand . you should have had a packet of assorted sizes of screw with the stand . you can also get the users guide by typing in make & model size
Jul 03, 2010 | Vizio L32 32 in. LCD HDTV
VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Mar 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Jul 06, 2009 | CTL Nexus NX3200 Television
Where/what do I buy to mount my tv on the wall?
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
Mar 27, 2009 | Dynex DX-LCD37 TV
PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
May 03, 2008 | Protron PLTV-37 37 in. LCD Television
Dynex 32 in. LCD Flat-Panel HDTV Logo
223 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
